Question about Panasonic TH-42PX60U Television
PLASMA T.V. PANASONIC TH-42PX600U ALMOST NEW WENT DEAD. MANUAL BUTTON LIGHT BLINKS A CODE OF TEN. T.V. IS JUST OVER WARRANTY BUT WAS USED FOR ONLY A FEW WEEKS. WHATS WRONG AND WHAT IS COST?DO I HAVE TO GET A TECH SENT TO MY HOME?
  • 1 more comment
  • sab28l Dec 29, 2007
    Have the same problem with Panasonic TH42PX60U. TV is a little over a year and a half old. When I turned it on, a few seconds later, we heard a loud pop, and now it won't turn on. The power button blinks, but no sound or video. The cable box which is using the same outlet was not affected. No lighting or bad weather to cause this. TV is still under warranty since I got the extended warranty, only I hope they don't try to weasel out of it. Does anyone have any idea what could cause this?
  • Anonymous Jan 08, 2008
    Same exact problem happened to me this weekend.
  • 1mad dude May 17, 2008
    was watching tv when the tv made a pop and turned off when pluged in the power LED flashes 10 times only my wife and myself live at the house we both work alot only get to watch the tv on the weekends it was about two weeks out of warranty when this happen
    Sergeant:
  • 395 Answers
Ten flashes from the light is a problem that needs to be issolated by a tech the 1st board to check is the PA board,and all the boards require authorization from panasonic to replace. that is why a tech must do the repair. if the unit is under warranty they must honor the warranty. extended warranty must honor the agreement you signed or purchased. there are a total of 6 boards that can cause the 10 flashes and can be costly to repair that is why I say when ever buying these types of sets get the extended warranty. these sets are no the sets of old they are not componet level repaired but board level repaired.
Posted on Jan 05, 2008
I have a Panasonic TH-42PX600U and the RF board displays a red light and the screen says no channel found. Can I change the board myself, does it just snap into place
if you have the right tools then you can do it, make sure unplug the tv unit first while replacing the board. then mark or put a label to the connector that you were disconnect not to interchange that can cause of damage to the other board.
Sep 17, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button blinks TEN times.
Check and see if there are any blown caps on the power supply. If there are replace them or change your power supply.
Thank you
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I plug in my TH-42PZ80U and it doesnt turn on but a red light blinks ten times.
Apparently this common problem is due to a faulty power board. Contact Panasonic for a replacement if it's under warranty (hopefully) or a local repair shop. Good luck!
Jun 06, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
I need a manual for the panasonic t.v. th 42px600e
user manuals here http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PX600U
direct link to the manuals
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U-MULTI.PDF
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U.PDF
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Panasonic TH-42PX600E 42 in. Plasma...
Shut off- won't turn on with control or manual. Red light blinks ten times then off then on again. Power went off and did this before. unplugged to re-set but still won't turn on.
Power board it dead.Know how to solders?Take the tv aparts,check the power board for capacitors that puff up or burst open.Replaced these capacitors.Or buy a
whole power board.Tries Shopjimmy.com,Ebay.com for refurbish power board.
Jan 19, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
TV clicked and went blank...no picture, no sound. Power light blinks ten times in one second intervals and then pauses for about five seconds.
Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
No power
I would guess it's the power unit for the TV itself.
If it's still under guarantee I would have thought you should be able to get it replaced.
Feb 19, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PX60U Television Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
