Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 2488 i got my monitors hooked up but only can hear alittle bit of sound and i got them turned all the way up,what am i doing wrong
    Novelist:
  • 189 Answers
In the monitor section on the 2488 console (upper right) make sure your monitoring source is set to 'stereo'. Then make sure your 'monitor level' control is turned up. The 'stereo' fader (sub mix fader on the MKI, stereo fader on the MKII).
Posted on Jan 03, 2008
  • Dave Hart Jan 05, 2008
    My last sentence was supposed to read:
    The 'stereo' fader ('sub mix' fader on the MKI, stereo fader on the MKII) also controls the monitor output so insure that it isn't set too low.
Just got the Tascam 2488 neo. I'm concerned that due to the size of the room I can't place the unit far enough away from the speakers to ensure I don't damage the unit with electro magnetic fields....
Assuming you are talking about your monitors for your 2488, the first thing I'd do is to consult the manual for proper placement of the monitors relative to the 2488. A quick rule of thumb is to place the monitors at ear level to the left and right of the 2488 so when you sit facing the 2488 yo will have one monitor facing each ear essentially. Again, consult your monitor manual as it will show the best placement and don't worry about electrical fields, etc. I have my monitors to the left and right of the 2488, the 2488 in the center and a 21" flat screen computer display in the center of all that with no problems whatsoever. That is the accepted practice generally speaking. Hope this helps.
Sep 13, 2010 | Tascam 2488 Portastudio Multitrack...
Just bought a new Tascam 2488 portastudio. Following directions to record first song, but I can't get sound through either headphones or monitor outputs. I know I have a signal because I can overdrive it...
Read page 19 under Monitor section.You have to assign the signal to the monitor output you want. Page 36 has the details. All the info you need is here with some updates:http://www.korg.com/product.aspx?pd=191
Jul 26, 2009 | Tascam 2488mkii 24 Track Recording...
The click track on my TASCAM 2488 Mk 2 won't click
There is likely an amplitude setting (probably available in a menu) for the click. Make sure that is turned up.
Jul 18, 2009 | Tascam 2488mkii 24 Track Recording...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Connect yamaha keyboard to tascam 2488 MKII
There are 8 inputs on the back. 4 of them support XLR type microphone connections, but also double as 1/4 inch and the remaining four are just 1/4 inch. These are all line level inputs and you can use any of them for a keyboard hookup. Typically you might leave the XLR inputs (A thru D) available for mics and take the next two (E and F) to use from your keyboards L and R outputs. Then just assign those inputs to two adjacent channels (tracks) or one of the stereo pairs, turn up the input levels for those inputs and the faders for those tracks and you'll be able to hear the keyboard playing through the 2488 (or whatever monitors/or stereo you have hooked up to it for monitoring). To record the keyboard simply arm whatever tracks you have those inputs assigned to for recording and record away.
bd.
Oct 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Aug 31, 2008 | Tascam 2488 Portastudio Multitrack...
Lost manual to Tascam 2488
Hi supa
All you seek is in the manuals... Try the quick start guide first, and then move on to the full manual.
Link to the Tascam 2488 application guide:
Here's the link to the Tascam 2488 quick start guide:
Good luck and thanks for using FixYa
regards
Graeme
Mar 04, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
http://tascam.com/Products/2488/2488_AppGuide.pdf
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
146 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
