Question about Compaq Presario M2000 Notebook
Screen went blank
The computer shut off and will not power up - could this be because it was on the bed and maybe overheated? if so, is there a compnent that can be repaced?
    Sergeant:
  • 263 Answers
First you need to know what is wrong.. you have to check if you have power (batery ,electical conection) or you can try to reset that by taking out the batery and try again that problem can be a faulty batery ,faulty ac adapter or the big problem prosesor due to the overheating if thats the case
Posted on Dec 27, 2007
My dell studio 2558 screen is blank and the backlight is on. what is the problem?
your inverter might have went bad. thats what gives your screen the charge
Jun 04, 2011 | Computers & Internet
BLANK SCREEN
? try removing the battery and then connect the adapter to turn on the computer
? if it is turning on then disconnect the cable and hold down the power button for 2 mins and try turning on the compute
Mar 13, 2010 | HP Pavilion TX2000Z Notebook
My acer aspire laptop has a blank screen when it is turned on it was working fine and I pressed alt+f10 then it went blank with just a white blinking cursor
Hold down the power button until the computer completely shuts off, wait 10 seconds, power it back on.
What happens?
Nov 21, 2009 | Acer Aspire 5720 Notebook
Monitor made a popping sound and went blank. no computer or tv signal coming through.
Sounds like a Power Supply comcponent failure in the high voltage panel supply circuit.
Backlight power seems to be ok.
Can only suggest obtaining repair quotations vs. Replacement purchase?
Oct 02, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
My acer extensa 5620z has just started to shut itself down and restart today. It has done this about 5 or 6 times now in the last hour. The last time I started it up (after powering off), it had sat and...
well its an overheating issue
looks like there is no air current going inside your laptop so its one of two issues
either you are putting the laptop on some soft area (like bed or sofa).
or (and thats what i think it is) the fan is not working properly or maybe not working at all.
so check the fans because if it is the fan then its normal you will have your computer restarting and shutting off once every 15 minutes range because the CPU is overheating and it should shut down to prevent CPU from getting damaged.
let me know what happened with u
Sep 03, 2008 | Computers & Internet
No output
if you are using pci or pci-e the motherboard maybe bad on the driver slots,if using the onboard system on the motherboard it is out and needs replaced. lala linda
May 31, 2008 | Biostar P4M80-M4 Motherboard
Starting up
press the power button for some seconds
Jan 29, 2008 | Computers & Internet
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
Computer turns off by itself
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE. The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared. If you are computer savvy, then try the following - if not, take it down to a computer shop! 1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back. 2) Remove the 3 screws which hold in the heat sink in place. 3) Remove the heatsink 4) Take the dust out 5) Re-assemble a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste. Good Luck!
Oct 30, 2006 | Toshiba Satellite 2060CDS Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
