Washer fills, but won't start wash cycle....makes buzzing sound
I have an old Maytag top load washer that will fill with water and when it's full, it will just make a buzzing sound and the wash cycle won't start. Sometimes, if I just leave it on, the buzzing will go away after a few minutes and it will finish washing. My roommate tried leaving it on and she said it started smoking. What should I do
  • 1 more comment
  • scruffy lady Feb 29, 2008
    fills but makes buzzing sound and won't wash
  • Patsy
    Patsy Dec 17, 2013
    Mine doing same except no smoke just hot smell
  • Anonymous Mar 30, 2014
    makes buzzing sound and then times out
Try replacing the timer switch..I had the same problem on my Simpson 175..
Posted on Dec 26, 2007
No water will pour down to start a wash
First is the supply turned on? Do you hear a buzzing sound when starting a load? if not, it may just be the fill valve assy/ solenoid. A reasonable cost for this part is about $15-20 plus 1/2-3/4 hours labor. If so the buzz indicates the valve is attempting to open or opening and there is an obstruction in water line or supply may be off. Do any of the cycles work? If nothing works some models lock out with a lid switch. I have seen alot of failures in this model see link Maytag Legacy Washers amp Dryers I hope this answer helps in some way. Hard to diagnose when not at unit.-Mtlgod
Dec 15, 2015 | Maytag Centennial Top Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
912 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
