Question about Samsung SC-D23 Mini DV Digital Camcorder
Black screen/record/playback. camera powers on but no picture is on screen you can record but still get no picture screen stays black in record mode and standby mode any suggestions thanks So - what is the solution? Do I need to send it off for repair??? Is this a problem with this model that I can get a recall on to fix for free?
  • dben Feb 16, 2008
    We had the same problem. We sent back to samsung for repair. They said it could not be fixed. They repaced it with the cheapest samsung made. SCD371
    Problem Solver:
  • 11 Answers
Join the class action lawsuit regarding this known problem.
Posted on Mar 09, 2008
  • 4,402 Answers
Lcd ribbon is bad have to send in for repair
Posted on Feb 19, 2008
Screen black. Everything else works perfectly.
To my understanding that you do not see live view in camera mode to record and camcorder playback old recorded tapes correctly and you get picture in LCD.
If it is true then please check lens cover that need to be slide down to get live view in camera mode. If problem still exist then 2 possibilities, either aperture in lens mechanism is bad or ccd imager is defective.
In that problem, camcorder needs qualified tech to fix it.
Let me know any further query.
Nov 03, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD Screen Stays Black
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
Nov 25, 2008 | Sanyo Xacti C6 Camcorder
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Aug 27, 2008 | Canon Cameras
Black spot in display
If the camera operates normally and the only problem is no picture is visible on the lcd in record mode and playback mode,then the lcd needs to be replaced.
Jul 31, 2008 | Casio Exilim EXZ1050 Digital Camera
Black screen in shoot mode
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
Hope this helps.
May 31, 2008 | Canon PowerShot S2 IS Digital Camera
No playback
Can you see what is being recorded while recording on the screen?
Apr 16, 2008 | Panasonic NV-GS17 Mini DV Digital...
Black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Oct 19, 2007 | Sony Handycam CCD-TRV328 Camcorder
This sounds like the CCD sensor is faulty ( this is the device that generates picture in both v-cams and normal digital cameras and sits behind the lens ). Playback is fine but no image ( or very 'noisy' image ) in capture mode. Easy to repair but one has to put a new CCD block in.
Sep 03, 2007 | Cameras
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Samsung SC-D23 Mini DV Digital Camcorder Logo
218 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
