Question about Canon EOS 400D / Rebel XTi Digital Camera
How to switch on Auto Flash in Auto mode
I just got a new canon rebel XTi 400D. In the full auto mode my flash does not pop up automatically. I do not know if I have pressed something by mistake while handling it in the beginning did the problem or not. Can anyone tell me how to switch the auto flash on in the auto mode?
    New Friend:
  • 12 Answers
Excellent..good its worked for me
rgds
wilson
Posted on Feb 12, 2013
    Problem Solver:
  • 9 Answers
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-upHow to switch on Auto Flash in Auto mode - 1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Posted on Feb 19, 2008
  • 3 Answers
In the auto mode every manual buttons are being override so it works automatically..its not compulsory that the flash will work every time... as the camera determines when to use it or not...
i suggest you to visit the service center
Posted on Feb 06, 2008
Internal flash pops up all the time
Is your camera always in the auto mode? Try to put the main dial to P. Your camera is almost automatic, but won't use the flash, unless you put it up yourself.
If your flash pops up, even when the camera is of, you have a mechanical problem. Something broke off.
Feb 16, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
I have a canon rebel xti and the flash pops up but doesn't flash even when its dark this is when the setting is in full auto. any ideas? could the "bulb" have broken?
The short answer is yes, that is possible. It's also possible there is a circuitry problem. You will want to verify by trying to use an external flash and making sure it still works. The flash assembly is replaceable if needed.
Thank you.
Mar 08, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d mode dial does not select modes
Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Built in flash problem
most likely you have set the camera to the auto mode and you are shooting in a place with plenty of light.
your camera has a sensor which activates the flash when needed.
you can set the camera to the manual mode so that you can chose the flash to work even in the day.
Aug 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
303 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
