Question about LG 790SC (White) 17 in.CRT Conventional Monitor
GPS LG 790 remote
Since the "manual is of little to no do you install the steering wheel remote?
The manual is all on disk. I have this model and attached the remote with little problems. One caution is to make sure the screws are in tightly as they are very short.
Posted on Apr 05, 2008
0 characters
1 Points
My LG tv model number M2762DL will not show a picture. On the screen shows a code V3.14.0. What is the problem?
Somehow, you have gotten to a firmware information screen. Try pressing OK and Exit simultaneously on the LG remote. (Note: this doesn't work if you use a generic or other universal remote.) If you don't have the remote, you can try pressing Menu and OK on the TV. (These are the second and third buttons from the left.) I've only seen the remote method work.
If that works, you'll probably need to open the input list and change the current input. Press Input on the remote or on the TV (the leftmost button).
I hope this helps.
Jan 16, 2015 | LG Electronics M2262D 22" LCD Monitor
My lg 23ea63v has black lines at the side
suddenly one day my remote is not working... i brought new another remote but both cannot work..plz help me
Dec 25, 2013 | LG Computer Monitors
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
You have lost your original remote and got into this by pressing info select and the option 7 UART Download. Happened to my 95 year old aunt in assisted living. You will need the original remote and simply hit (EXIT) or another LG branded remote that has the (ROUND RETURN BUTTON) on the left. Once you accidently get in to this, I have not found a universal Zenith remote that can get you out even though Channel up/down and basic funtions work.Bud retired Bud's TV Service.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
Instruction Manual for the LG W2453TQ Monitor Please Many Thanks
You can download the user manual of your LG W2453TQ monitor from this link which I uploaded for you.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Jun 15, 2010 | LG W2453V-PF 24" TFT Widescreen Monitor
Easy set package won't open. Monitor Driver won't install.
Hi mquinhoneiro,
I got the same problem. Probably there is something with EasySet Package. First time I installed driver + easyset like instruction said a I got "osd locked".
My solution:
1. Unistall your ati/nvidia driver with control panels
2. restart computer
3. you monitor probably will display 640x480 standard resolution
4. system recognise your vga card and install standard driver
5. restart
6. install lg driver depend on our monitor and connection
7. then should work. if not
b) install again but this time when you press install hold for 10 seconds  menu button.
8. update driver from nvidia/ati site.
For me this help but easyshare wont install again. But I don't use it .
Anyway monitor is good for the price but have little "cool" colors (perhaps from blue lcd led).
My configuration for ~6500k setting
gamma 0
red 55    ( 60 if you want more red)
blue 55   (45)
green 55  (45)
brightness 48 saturation 70
Apr 20, 2010 | LG E2350VR 23" Monitor
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Dec 26, 2007 | LG 790SC (White) 17 in.CRT Conventional...
LG 790SC (White) 17 in.CRT Conventional Monitor Logo
81 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
