My Dlink router lights just flash constantly and never stop, its the dlink logo and all four lan lines flash but the power light doesn't come on and niether does the internet symbol
Not a good sign. Have you tried resetting? You'll find a reset 'hole' on back of router. Press and hold with a pin for 15 seconds or until lights go out and come back on. Upon resetting, you will need to reconfigure. Disconnect sat/cable modem while doing this. Use the passcode and admin URL address on bottom/back of router to get to configuration. Should also power off modem and power back on when done configuring to reset the Internet connection.
Please re-post if you need help with configuring the router.
Has bought a headache from D-Link. Problems permanently. My apparatus (DIR-615 rev. A1 firmware...
(More)
Has bought a headache from D-Link. Problems permanently. My apparatus (DIR-615 rev. A1 firmware 1.10) does not wish to work as it is stated the seller of the yielded commodity. When a feeding disappears or disable a router from an electricity all my patterns disappear. After it AGN you switch on it is necessary to do a pattern AGN. It does not accept Thus conserved pattern of a router. That is, after apparatus reboot - a standard pattern (factory). Supports from D-link absolutely are not present any...
Replaced Comcast analog modem with digital Docsis 2.0 modem and Lynksys router will not connect to...
(More)
Replaced Comcast analog modem with digital Docsis 2.0 modem and Lynksys router will not connect to internet explorer.
hi i cannot connect to my isp , the wireless works. I am able to run 2 other computers OK , but...
(More)
hi i cannot connect to my isp , the wireless works. I am able to run 2 other computers OK , but not my wifes or daughter. They previously had been able to connect. My daughter is using a MAC. Its Christmas day and everyone wants to go online !
how can i set up virtual server in my netgear modem DG834GSP FOR remotely login ip camera.my lan ip...
(More)
how can i set up virtual server in my netgear modem DG834GSP FOR remotely login ip camera.my lan ip is 10.1.1.3 and ip camera ip address is 10.1.1.4.do have option for virtual server or any other option in netgear.pls let me know.thanks
