Question about Microsoft Xbox Console
Original xbox Indicator light flashes red. Error code 16 in upper left hand corner with oriental language on screen. Error code 16?
  • 2 more comments
  • Anonymous Jun 23, 2008
  • lady4321 Aug 24, 2008
    my original xbox flashes red and green and says require service ang other words in chinese or another language,what do i do?
  • Anonymous Aug 28, 2008
    error 5
  • stoner4life Mar 18, 2009
    ok i have an xbox and i copied all the file with ftp and then i tried to relpace the hard drive with the other one and now nither of the hds work i get error code six on them
  • 21 Answers
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
If you get an error 13 after this, please read up on the error 13 explanation!
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the (older) dashboard (4920) that older slayer cd installs and the new dashboard/kernel versions found in some new xbox's and found in xbox's that have been connected to xbox live (when you go on xbox-live, it'll upgrade your dashboard file to i believe it is now 5659.03. This dasboard is incompatible with the dash that (old) slayer cd installs (for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on most new xbox games! Be sure to 1st unplug your ethernet cable before you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar
Posted on Dec 30, 2007
How to fix a origanel xbox when it buzzes and says disk can not be read?
Posted on Oct 14, 2008
Give up and your going to have to get a new xbox buddy im sorry to be the barrier of bad news but thats wats going to have to happen. im selling a moded xbox for 180 its got 23 games and a larger hard drive and all you have to do is copy the games you rent right to the hard drive and no discs are needed but if you are intrested just call 1 914 615 1943 or 1 914 528 0882
take it easy buddy by the way my names little jerry just ask for me
Posted on Jan 10, 2008
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Red Light Indicator Flashing??
There is an old message stuck in memory. Hold down the OFF button on the base handset for 10 seconds.
Dec 02, 2009 | Uniden DECT 6.0 Cordless Phone ID
Was given a original xbox but wont work? I dont have manual, have hit reset, the button or light flasing on front? a page come up with a 06 in left corner, and lots of different language on screen?
error Code 05/06 is usually Hard-Drive related.
The drive has been left unlocked, or shutdown powered off while a game-save is in progress.
The xbox only boots with the Hard-drive is locked, Otherwise it will Frag ( red/Green on startup )
Mike @ Compurepair.
Nov 06, 2009 | Microsoft Xbox Console
Red light in bottom right quadrant
Hey there sounds like you might have the red ring of death. Which is usually a hardware failure.
1. Try turning your Xbox 360 on and off.
2. Make sure all your cords and cables are firmly plugged in.
3. Once you have tried all of those trouble shooting tips, turn on your xbox and see if you get an error screen.
4. This will usually be a black screen with multiple languages on it. on the upper left or right corner a letter E followed by a number will appear.
5. If it is an E74 error, then call 1-800-4my-Xbox
6. Microsoft has extended the warranty for Xbox 350 with the E47 error
Don't worry if your warranty has expired they will extend it when you call.
Oct 07, 2009 | Microsoft Xbox 360 Console
Got on red light,E74
An E74 error is when the lower-right quadrant of the ring piece indicator flashes red and displays an error message in multiple languages: "E74 System Error. Contact Xbox Customer Support". The error is caused when there's a video problem with the Xbox's hardware scaler chip being damaged. As of April 14, 2009, the E74 error is now covered by the three-year extended warranty.
Aug 09, 2009 | Microsoft Xbox 360 Console
Ring of death on original Xbox
An indicator light that is flashing red indicates that there is an Electrically Erasable Programmable
Read Only Memory (EEPROM) error and that Xbox cannot start. EEPROM is a memory device that does not lose the information programmed to it when power is lost.
This is where items such as language setting, video modes, audio modes, and game region are stored.
Back to the top THINGS TO TRY
1. Remove all discs from the Xbox console.
2. Turn off the Xbox console and leave it off for thirty seconds.
3. avoid overheating and other problems.
Make sure the Xbox console is not located near a heat source.
Heat sources can include TVs, computers, monitors, and other electrical devices.
Make sure the vents are not blocked. There are vents on the left and right side,
and on the rear of the Xbox console. Make sure each vent has at least six inches
of clearance and space for air to circulate. If the Xbox is inside a cabinet, move it to see
if this prevents heat problems.
4. After the Xbox console is set, turn it back on and make surethat you see a steady green indicator light on the front.
5. If the console continues to flash a red light, the console may need repair.
Aug 01, 2009 | Microsoft Xbox Console
Red light on original xbox suggestn servicing required
I can help you fix your xbox but i need the service code number in the top corner of the screen suggesting servicing. You can email me at c_a_messmer@hotmail.com
Aug 26, 2008 | Microsoft Xbox Console
Xbox flashing green and red
7 - kernel
This is a hard drive error. Your hard drive has died you can either replace the motherboard and hard drive as a pair or go through multiple steps with a modchip to allow you to create a new drive or lock a previously unlocked xbox drive to the password your motherboard has.
Create a new drive
Aug 24, 2008 | Microsoft Xbox Console
Original xbox amber flashing lights, no error code
sounds like maybe the video on the xbox itself
what connector are you using?
Jul 29, 2008 | Microsoft Xbox Console
Xbox
Flashing Red and Green has Numerous causes for eg: system failure. please mention the error code which is displayed on Top left corner of your TV screen as shown in following image.
Aug 26, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
1,582 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
