Question about Internet KM-2501P Enhanced PS/2 Multimedia Keyboard
Vista Software Wireless Connection
I brought a new ZT Desktop PC and installed Linksys software for my wirelss connection. I cannot get it to work. I keep receiving a error "cannot or install locate USB drive".
0 characters
1 Points
Mouse will not work. I've changed batteries, unplugged and re-plugged the remote device. It will not work. What do I do?
Have you tried pressing reset/connection button on the device? Some Logitech models may have a connection button on the receiver which is plugged into the computer. The receiver button must first be pressed then press the device (mouse or keyboard) reset/connection button. Some Logitech models you will have to go into the Logitech software to start the connection software then press the reset/connection button when prompted.
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
Logitech wireless rf keyboard and mouse quit
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
Jan 28, 2010 | Logitech Wireless Access Duo Optical...
I have a wireless keyboard and mouse S520. Changed all batteries but it still doesn't connect/work. I plugged in receiver - still nothing. Bought it a few months ago. Not happy! Can you tell me what's...
You have to download the software from and install it. The software will help you encrypt a connection and make it start working again. The software will prompt you to type in a set of numbers and the connection will be there again. Don't worry... your mouse and keyboard2.gif are not broken. This happens quite frequently.,en
This should be the link you need to find the software for your keyboard
Nov 05, 2009 | Logitech Wireless Access Duo Optical...
Wireless Optical Desktop 2000 keyboard problem
Did you install any software that came on a CD with the devices or did you just plug them in and let Windows try to download or install a driver automatically?
If you have not done so, I would install driver software from the CD it came with and make sure there is not any trick in the instructions to get it working correctly. Also did you check for a sync button on the keyboard anywhere? There could be a button you have to press on that as well as the mouse to get them working.
Mar 18, 2009 | Microsoft Wireless Optical Desktop Comfort...
Keyboard not functioning properly
I had a similar problem with a new MS 4000 Keyboard. I found that I had two versions of the IntellPoint software on my Vista system. I uninstalled the older version (which came with my new computer) and the keyboard seems to be working well now. Check your system via the Control Panel, Install/Uninstall Programs and look for the MS IntellPoint software. Good luck.
Jan 06, 2009 | Microsoft Wireless Laser Desktop 4000...
Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Dec 30, 2008 | Logitech 967437-0403 Keyboard
Microsoft Wireless Optical Mouse Not Connecting
when do resetting chk whether u are getting blinking light on mouse. if yes and after resetting the light is steady then ur mouse if fine. if u are using vista then use the os disk go to the os installation screen and chk whether the mouse is active there. if yes then reinstall drivers or update it.
Sep 21, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft wireless keyboard
check the reciever of your keyboard ,maybe its not inserted properly.
Mar 17, 2008 | Logitech Cordless Desktop S 510
Installed software, connected signal usb part - neither mouse nor keyboard work at all
Yes!!! it shows up on your device manager. Usually, it has a big yellow question mark logo on a specific device that it didn't function.
Jan 30, 2008 | Microsoft Wireless Laser Desktop 4000...
Either the keyboard or the keypad is recognised not both.? Vista problem
Are you connecting by plug and play or did you download the software? (setpoint 4.0) I had the same problem and contacted Logitech and was told that the radio freq. waves between wireless routers, monitors, etc. will interfere with the product causing it to loose connection. Pressing the connect buttons will not fix the problem you need to download the software..(get it from the site) I have had many cases like this and found if the software is downloaded it solves the problem. Hope that helps you.
Oct 03, 2007 | Logitech diNovo Media Desktop 9673120101...
Internet KM-2501P Enhanced PS/2 Multimedia Keyboard Logo
20 people viewed this question
Top Internet Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you an Internet Keyboard and Mice Expert? Answer questions, earn points and help others
