Question about Samsung SYNC SGH-A707 Cellular Phone
White Screen No Work
Hello my problem is when I dropped my phone, the screen went all white, and doesn't display any other function, but the phone still works, I can dial, open the menu, but I can't see anything on the screen, its just white. Please help.
    Brigadier General:
  • 7,752 Answers
Have the LCD/screen replace...take it to a mobile tech and have that done.
Posted on Jan 01, 2008
    New Friend:
I had the same problem about 6 months back. I took the mobile to repairing shop, they said it was Processor problem and they changed the processor. It worked fine for 3 days and then again screen became white. I took it to the same shop and asked to change the LCD. With a new LCD the mobile worked for 6 months and now it is having the same problem.
So what I concluded is that, there is something wrong in the mobile IC which slowly damages the LCD.
Posted on Jul 17, 2013
E800 has white screen i must have dropped it a few times and is always having a white screen ? Please help.
Posted on Sep 22, 2008
White spot on my laptop screen
Increase color depth for strange colors on your display.
If that doesn't work you probably have dead spots on your screen that no longer work. This means that your LCD assembly is no longer functioning and you will need to replace it.
Apr 04, 2012 | LG Computers & Internet
My phone screen has went white!
The problem with your phone is that the flex on the screen of your phone is damaged.
All you need to do is to change the flex on the screen of your phone and you will see that your phone will start to display back.
Just change the flex on the screen as advice and you will see that the screen of your phone will display back.
Take care.
May 18, 2010 | LG VX8300 Cellular Phone
I dropped my iphone on the floor and there is sound coming from it but the screen is completely black, Will i have to buy a new screen?
Hi!
If your screen is not having a crack on it then there is a possibility that it can work again.
But if it has a crack then you need to buy a new screen.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 06, 2010 | Apple iPhone 3G Black Smartphone
My nokia n72 have only white display but mobile working well but only display problum plz give me solution
HELLO.
You need to told the cost of the problem though there are many reason that can lead to white or blank screen,
A) Over charging B) drop from high place ,C) fall in water etc.
The way out to solve the screen problem now is to make a change of the screen sothat you can operate your phone again
befor this can come to reality you need to take it a very good phone work shop around you to fix it up or if you can do it your self.
thank you.
Mar 17, 2010 | Nokia N72 Cellular Phone
Diplay is blank (just white lighted screen) does
hello,its a flex problem or could either be that your screen is faulty,i would advice you take it to a mobile phone engineer to fix it up for you.its can be fixed.thanks and you are welcomed.
Mar 09, 2010 | Motorola Mobility W385 Cellular Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Blank White Screen on Sony Ericsson K750i
try to dial emergency kol 112, or try to ring your network hotline number! if there is an operator that answer? your phone program is ok,just change your LCD, the Flex in your lcd is Damage!
Oct 13, 2007 | Cell Phones
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Samsung SYNC SGH-A707 Cellular Phone Logo
4,946 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
