Question about Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V5500 won't finish loading
Our DVDs will not play. We bought the Memorex CD/DVD Optidisc Cleaning disk. No improvement. Can you assist me with alignment?
  • 4 more comments
  • Anonymous Mar 12, 2008
    VCR side works fine, but when I insert any DVD, the display shows "LOAD" forever, and it never does load or play.
  • Anonymous Apr 06, 2008
    I have the same problem.
  • hamitime Apr 06, 2008
    same problem
  • dakota2 Apr 07, 2008
    same problem vcr works fine, dvd will not load! piece of junk!
  • TUNDRA May 20, 2008
    DVD STARTS LOADING BUT WILL NOT PLAY
  • Anonymous Aug 25, 2008
    same problem; was working like a dream and now can't get it to play any dvd; also bought the lens cleaner...got nothing; just keeps "loading" and "loading" and...;
I have the same problem. i opened it up and traced it to a bad motor on the disc spinner. part # is rf-300fa-12350. it's a cylinder shaped motor. can't get the cylinder apart to try to repair the motor though
Posted on May 03, 2008
Cd not pplaying
Crystal, try a different known working CD, if it does not play and has before, purchase a CD player cleaner kit and run it through the cleaning process or disassemble and clean as per instructions in attached links. Retry CD after cleaning, hope it works for you.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Memorex OptiDisc CD DVD Laser Lens Cleaner
http://www.bestbuy.ca/en-CA/product/insignia-insignia-cd-dvd-blu-ray-laser-lens-cleaner-ns-hcl303-c-ns-hcl303-c/10321627.aspx
How to clean DVD or CD player or recorder lens Sony RCD W500C
How to Clean CD Player
Jul 02, 2016 | Audio Players & Recorders
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Jan 03, 2010 | Samsung DVD-V5500 DVD Player/VCR
The DVD-VCR unit won't accept any DVD - blank or with content. It says "LOAD" but then ejects the DVD. Same DVD works in an identical Samsung unit in another room.
You may have a dirty lens on the DVD read head. There are CD/DVD cleaning kits available at some drug stores and electronic stores. Do not get a "CD cleaning kit" (that only cleans the discs), get a "CD/DVD lens cleaning kit" (it will have a special CD and cleaning solution) for $10 to $20.
If that's not it the DVD illumination LED may be dead. If it still plays CDs, but won't play DVDs, that's the problem. There are separate LEDs for playing CDs and DVDs.
Either way, if the cleaning doesn't work, it has to be fixed in an electronics shop.
Oct 06, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
I need to play all zone dvds on my samsung dvd v5500
HELLO
If you go to this website, I'm sure you will find the information you need:
www.videohelp.com and select DVD hacks and enter your make and model number!
Hope this helps you! :-)
Jul 28, 2009 | Televison & Video
Samsung v5500 dvd combo problem
When you get a whirring sound, some click and disk not engaging on some disks, and not others , that is because lens cannot read the inital track on the CD/DVD.
This is either because disks are scratched , dirty or ruined by light and heath, or because the lens is dirty.
Try using a lens cleaner like the ones here.
If that does not work, then the unit must be taken apart and the lens cleaned with cotton buds and isopropyl alcohol.
See :
How to Clean the Laser Pickup Lens on your DVD Player
Jan 01, 2009 | Samsung DVD-V5500 DVD Player/VCR
Can't read some burnt dvds
Try updateing your drivers firmware.
also cleaning the lens with a lens cleaning cd/dvd kit.
if that doesnt solve the problem then the lens system would need to be replaced -> better to buy a new drive.
May 01, 2008 | Samsung (SH-S162L/BEBN) DVD RW Burner
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Samsung DVD-V5500 DVD Player/VCR Logo
427 people viewed this question
Jerry Greenberg
Jerry Greenberg
