Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HDTV I want to purchase an HDTV and need to know if there are any special cable requirements to access HD channels. Will my present box work or do I need something else to make it work. I currently have a Motorola Dolby digital Interactive Digital Communications Box - Model #DCT2244/1661/AC. Thanks.
  • Anonymous Mar 17, 2014
    need downloadable manual
I don't think the DCT2244 has an RF bypass output and it is not HD enabled. Hence, you will need a cable splitter so that the unscrambled splitter outputs can go to the TV and the CABLE BOX independently. This will enable you to pick up any available unscrambled HDTV signals your provider offers as well as the channels you are subscribed to that require the box for decoding.
Posted on Dec 29, 2007
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
Digital channels are not working
If your TV is connected to a "cable" box, e.g. you're using cable TV ... then it is the cable TV box that determines what you can get (based on your cable subscription). Yes, I know that some cable TV and satellite TV service providers will only deliver HD digital channels when you pay an additional (monthly) fee for HD digital channels.
If you plug the cable directly into your TV (i.e. not use the cable box), you may be able to do a channel scan on your TV, to pick up the digital channels ... but you will loose the convenience of using the features that your cable box provides .
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
Does the Sylvania 22 HDTV require a special cable when connecting to my cable service. I do not have HD cable service.
Not necessarily. You can use the normal connecting cable but you may not get HDTV picture. Better is to connect through HDMI cable where you can view HD pitures on the channels transmitting HD programmes
Jan 06, 2010 | Sylvania LC-225SL9 22 in. LCD TV
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Connecting TV to cable service for HDTV
normally you need a converter box for hd because normal stations are broadcasted in hd.....its not common enough for them to do it...and you probably have to buy a package with your cable company for the hd channels. another your tv hd ready?
Sep 30, 2008 | Mitsubishi WS-48313 48" Rear Projection...
Antenna for my HDTV
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
Jun 25, 2008 | Panasonic PT-53WX54 53" Rear Projection...
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
402 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
