Question about Samsung Digimax S500 Digital Camera
Camara powers on but will not snap picture!
Everything seems to work normal, powers on as normal, view pics, LCD screen is normal, but when you press the shutter button to snap the pic the camera will NOT take the picture. The ready flash red light comes on as normal but no capture of the image. Why is this? Everything else is normal but for some odd reason I can not take pictures all of a sudden.
  • 3 more comments
  • lstrongnsd Dec 28, 2007
    I have the same problem. I can view, change modes, access all menu options, etc but the picture will not snap. Would love a solution, it was a great camera.
  • Anonymous Jan 01, 2008
    i have the same dam promblem whyyy????
  • Spoti Jan 03, 2008
    I have the same problem with an S500 my daughter owns. My problem was due to the flex circuit being "scrunched" in the case and popping off a chip capacitor(very hard to solder back on) This obviously happened during Mfg.. I am presently searching for a parts source for these cameras.
  • Anonymous Mar 03, 2009
    I have the same problem . I tried reset and it still won't snap a picture..
  • Anonymous Apr 29, 2009
    it wont let me take will take 1 pic when you first turn it on, then nothing. Euresverything else works,it just wont take pict
    Problem Solver:
  • 12 Answers
Did you just try to press the shutter button halfway?if in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Posted on Jan 12, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Image blacked out on LCD and can not see image in view finder
Try this, it may or may not work. Insert the Video cable plug in and out of its slot a few times. The cable when inserted turns the screen off. But sometimes corrosion can build up on the internal plug switch, also causing the screen to turn off. Inserting and removing the cable a few times can sometimes knowck off this corrosion.
Mar 27, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Lcd screen
Please go to nearest Sony Service Center for replacement of borken LCD in your camera. You can ask an estimate befor repair. Sony UK website is as follows...
Aug 04, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Black screen when camera is on
Thanks for the assistance. It is a problem that the mfg will have to fix.
Jun 21, 2008 | Fuji FinePix F700 Digital Camera
Black screen when camera is on...did you get an answer?
One configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Samsungs850 no pic in view finder
This is new. I see that according to the illustration, there is no Optical Viewfinder- thus you need the the screen to compose the images - Is this correct? As this camera is new to you carefully read up the instruction manual - especially the set up routine. If after a day or so you are still in trouble - take it back to the store for replacement. Do not interfere with the camera.
Jun 12, 2007 | Samsung S850 Digital Camera
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Sony Cybershot DSC P31
You have to check the CCD and this can be faulty. The picture may look hazy or lines mayy appear randomly.
Aug 11, 2006 | Sony Cyber-Shot DSC-P31 Digital Camera
Samsung Digimax S500 Digital Camera Logo
245 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
