Question about GE 46GW945 46" Rear Projection Television
No sound. Picture is perfect.
This tv has never given me any problem. Suddenly, the volume is not working. I there anything I can do to bring it back. I have to repair it myself.
    Sergeant:
    Champion:
  • 346 Answers
If you have any technical knowledge then you need to change the jungle Ic.
Posted on Dec 26, 2007
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
Toshiba lcd 52rv530u has sound but no picture completely black
Check its back light inverter board for the fault. This is a skilled work. Contact any experienced service technician to get this set repaired.
Jul 27, 2012 | Toshiba REGZA 52RV530U LCD TV
Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
Sound off
you are having problem on your tv with your tv sound ic this can be located ion the sound circuit just where the speaker is hooked up inside the set if you are not a tech have one repair your tv good luck
Jul 12, 2009 | Televison & Video
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
No volume
USE A SURROUND SOUND...I HAD THE SAME PROBLEM..JUST CONNECT YOUR CABLE BOX OR SATILLITE BOX TO YOUR SURROUND SOUND AND YOU WILL HAVE SOUND BACK..
Feb 07, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Volume up then pic gone
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Westinghouse LTV-46w1HD
The conversion board on the TV is iffy at best, to replace it is about $169 available cheapest at cfusion.com
Dec 25, 2007 | Westinghouse LTV-46w1 HD 46 in. LCD...
Sound but no picture
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Nov 17, 2006 | Akai LCT2060 Television
Televison & Video Logo
60 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
