Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 2488 Recorder
I have a tascam 2488 recorder. I have the recording down But Now how can I add effects to voice to give it that extra sound.
  • damo220 Jun 26, 2008
    With the tascam 2488, I cant figure out how to get reverb and effects on my microphhone before I record. I can get to the screen where it says reverb and I have changed the pre delay settings and all of the settings but I still dont hear any difference in sound, or by changing from hall, live, or studio, there is no difference in sound. I hold down the single mic effect and the channel that i prefer, and there is no difference.
  • 189 Answers
The 2488 has three effects types: “Mic” effects (compression, exciter, de-esser) you use while recording or insert into a channel; multieffects (distortion, amp model, modulation effects, delay, wah, etc.); and an internal send effect (reverb, delay, chorus, pitch shift, flanger, phaser, and gated reverb).
To add effects to an already recorded track you can assign the effect using the internal send loop for the channel and then bounce the track to print a copy of the track with the effect applied.
Posted on Jan 03, 2008
  • 44 Answers
If the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Posted on Dec 26, 2007
Also the tuner does not come up on my 2488
Re: Tascam 2488Hold down the 'SHIFT' button, and press the 'Tuner' button to get the tuner on screen. Press 'Home' to exit the tuner
Mar 30, 2012 | Tascam 2488 Portastudio Multitrack...
Using effects
You can download all of the manuals and guides for the Tascam 2488 for free at this address:
If you believe your machine is broken you will need to contact Tascam directly and they will direct you to an authorized service station:
Mar 01, 2011 | Tascam 2488 Portastudio Multitrack...
Hi im new to using the effect send on my tascam 2488 neo. How do i set the connections? how dose it work?
I think if you had the manual you would know the answers.
Register and download the manual for free at
Search for "Tascam Portastudio 2488"
Jan 05, 2011 | Tascam 2488 Portastudio Multitrack...
Recently purchased the Tascam 2488 Neo Digital/Microphone Effects
Assuming you have your mic plugged in properly and all is working well save for this one issue, do as follows: press the SELECT button on the track/channel which has the mic on it. Then press the SEND button over to the right of all the tracks. The button is right under the EQ button. After you press the SEND button, a screen opens up and you can send reverb to that channel/ much as you want. I hope this helps.
Feb 17, 2010 | Tascam 2488 Portastudio Multitrack...
No effects
Internal effects, press 'SELECT' then press 'SEND' then, depending on which type of effect you want, press 'SINGLE' or 'MULTIPLE' & scroll up or down.
May 17, 2009 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Aug 21, 2008 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
Link to the Tascam 2488 application guide:
Here's the link to the Tascam 2488 quick start guide:
Link to the updated Tascam 2488 manual:
Link to the Tascam 2488 manual additions:
Link to the Tascam 2488 MIDI Parameter Mapping
Link to TASCAM 2488 Hi-Res images:
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
564 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
