Find out what kind you have - serial or IDE, get your replacement.
Remove the cover of the computer. Observe static electricity precautions. Find the hard drive. Confirm it is a serial or IDE type drive (IDE has a 40/80 conductor cable about 1 1/2 inches wide - serial cable is about 1/2 inch wide. Dont confuse with the power cable which is a Molex plug.)
Remove 2 or 4 screws if rail mounted. Unlatch if other style. Unplug the cables - check the pin outs - reinstall and get ready for the fun. (you may want to use the old drive - see below. If you are Cable Select (80 conductor wire) the master will be located at the end of the IDE and the slave will be in the middle. If serial, you will have to read the manufacturers direction.)
You willhave to use the manufacturers supplied software to prepare your new drive to receive information. When that is done, you are ready to reload the operating system. You do still have the key right??? No key - don't do this at all. You may be able to use your existing drive as "D" or as a slave (secondary if you prefer) ... to get your old files off or store your new files. All kinds of possibilities are opened to you with a second drive.
Have fun and good luck with your project.
We volunteers are paid with "bragging rights" if this response pleases you please leave positive comments.
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
my msn messanger will not allow me to send my webcam it keeps coming up ''We couldn't start your...
(More)
my msn messanger will not allow me to send my webcam it keeps coming up ''We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.'' but there are no other programmes running that i can see
