Question about Cobra 22 CHANNEL 2-WAY RADIOS
Cobra PR4100-2 WXVP with VOX
After switching VOX on. And setting to senstivity to 5. Nothing happens on either of my 2 units. Any ideas. Thanks, Dave
    Brigadier General:
  • 6,966 Answers
Hi Dave,
On some other models/brands, you need to use an external mic/spkr such as a headset for the VOX to operate. This may or may not also work for your model. Perhaps you can try getting hold of a headset that will fit your model and see if it works.
If you are already using a headset:
1. If it is a compatible model, then something is wrong electronically with your unit and you will need the services of a qualified communications technician;
2. if it is a generic or some other brand/model, then the pins, jacks, plugs or connectors may not be wired to be compatible with your Cobras. You need to get Cobra compatible ones.
Hope this be of some help/idea. pls post back how things turnes ouot or should you need additional information.
Good luck and kind regards.
Posted on Dec 31, 2007
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
Uniden turn off vox
Hi Jon,
The problem is easy to solve, so here goes:
vox indicates that your unit is set to work via the microphone(if you have one), and is activated when you start to speak, (hence vox=voice activated microphone), if you don't have the microphone that came with the unit, you will need to buy/borrow one and connect it to the unit, before you can turn off vox, so that the unit can work with or without the microphone(vox will no longer show), once you have done this.
I hope this helps.
Cheers,
Peter
Feb 22, 2013 | Uniden Radio Communications
Vox Tonelab LE. One of black buttons on my unit has got damaged and pushed under the metal casing so it is permanently pushed down. (Used to set preset values). Has anyone got a procedure for taking this...
Hi it could be that the switch has failed if it is something you are not confident with ask an independent electronics repair shop for some help. Sorry I cannot help more but I cannot see how the switch can be seized in the on (Depressed) position.
Dec 21, 2017 | VOX Amplification Vox Valvetronix Tonelab...
What does vox and rog. Stand for on the cobra microtalk
VOX is the abbreviation for Voice activated transmission, and ROG is likely the abbreviation for Roger Beep, which is a small beep or series of beeps at the end of a transmission that alerts the other person you are talking too that your transmission has ended. this is mostly used when signals are noisy, as the beeps are a sure sign that you have finished your transmission.
Aug 29, 2011 | Cobra MicroTalk PR 4200-2 WX (22 Channels)...
Washer will start the spin cycle and stops spinning after 5 to 10 seconds
i would say that theout of balance switch is to senstive. what happens after the ten seconds does it start again, for ten seconds
Apr 12, 2010 | GE Washing Machines
Tape stops
There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
Aug 13, 2009 | Dictaphone Audio Players & Recorders
General modifications wanted
vox is for the voice activation so you dont have to press the tx button when you speak.it automaticly opens the tx . so dont turn up to hi or everyone will here what you are talking about.
May 16, 2009 | Cobra Radio Communications
Open Questions:
Cobra 22 CHANNEL 2-WAY RADIOS Logo
345 people viewed this question
Top Cobra Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
