Question about Philips HTS3410D/37 700W DVD Home Theater System System
Not powering on
I have the Phlips HTS3410D Home Theater System. The system doesn't power on. The LCD light just blinks. Any help on this is appreciated.
  • 2 more comments
  • Brucius80 Dec 29, 2007
    Same problem as above. Went away for the weekend and was doing this when I came home.
  • Anonymous Jan 03, 2008
    me too. I wonder if it's a clock thing. I'm going to mess around with it for a bit. If I learn anything, I'll let you know.
  • Anonymous Feb 25, 2008
    same problem sounds like this unit sucks
  • Tamilrasigan Jul 06, 2008
    Thanks. Working great. Appreciated
  • 3 Answers
I solved this problem on my HTS3410D.
Inside there are two circuit boards, the power supply board and the audio/video board.
  • First, unplug your unit and let it sit for a few hours.
  • Now open the unit up, and unplug all of the connectors going to or from the power supply board. You can easily tell which board is the power supply board because it's the one the power cord plugs into.
  • Unscrew the four mounting screws that hold the board to the case.
  • Using a pair of needle-nose pliers, squeeze the two white plastic clips that hold the board to the case (one at a time), while gently lifting the board away from the case.
  • Now that you have the board out, feel the tops of all the capacitors (they look like this). Healthy capacitors should have a totally flat top. (There is probably one that is covered in some sort of heat shrink, so you can't feel the top.)
  • One capacitor most likely has a slightly bulging top. That is the culprit.
  • Using a soldering iron, carefully remove the busted capacitor, making sure to note which side the stripe is on.
  • Buy a replacement capacitor at Radio Shack or that has the same capacitance (e.g. - 1000uF) an equal or greater voltage, and an equal or greater maximum temperature.
  • Insert and re-solder the replacement capacitor in the same orientation as the one you took out, then trim the excess leads.
  • Reassemble your system, and you're done.
The capacitor that died on mine was 1,000uF, 16V, 105°C. It was located fairly close to where the power cord comes in to the board. I replaced it with a 1,000uF 50V capacitor, and the system powered right up like a champ. The entire process took me about an hour.
I hope this helps some other people have similar results.
Posted on Mar 20, 2008
  • Lui T
    Lui T Feb 19, 2014
    I hope someone can answer me. I have the same unit. Used it for years. Since 07. What capacitor did you replace? Cxxx
Posted on Jul 06, 2008
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Power light flashes on and off, unit will now power up
check for a swollen capisitor on the power supply board replace with one of a higher temp ie C rating
Oct 12, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
HTS3410D power light keeps blinking
This seems to be a common problem with this model. It seems as though there are about FIVE electrolytic capacitors in the power supply PC board that have failed or dried out.
They can be replaced by someone that has the dexterity, knowledge and tools to de-solder and re-solder PC board components. Otherwise you may seek a local electronic technician. The parts cost about $5.00. Labor may run you $30 or more.
Hope this helps. I also am looking for a remote for mine, if someone has a dead HTS-3410D.
Jun 30, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
Jan 11, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
The power button on my Philips DVD player blinks.
The Front PCB might be damaged. Check the front PCB
Jan 10, 2008 | Philips LX3000D System
454 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
