Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing machine does not empty the water out and the white thing in the middle will not turn.
Help
  • TCJester Jan 02, 2008
    Couldn't the problem be with the spin cycle and not the pump itself?
    Scholar:
  • 196 Answers
Need to replace water pump. The transmission will not allow the unit to spin until most of the water is drained out. The pump is located on the front of the moter and can be accessed through the bottom of the machine.
Posted on Dec 30, 2007
My Russell Hobbs RH1042 5Kg White Washing Machine won't intake softener when I put a wash on, it just stays in the drawer. It is brand new so won't need cleaning out? Can anyone help?
have done all the cleaning with toothbrush ran the machine on a boil wash frequently on empty bought all the washing machine cleaners used white vinegar soda crystals all to no avail not taking fabric conditioner and the filter at the bottom of the machine after each wash filling up with water at my wits end any help please
Aug 17, 2012 | Washing Machines
Stopped in middle of programm, how do i empty the water
if it stopped in the middle of your wash you can either get a bucket or a shop vac to empty it out either way you have to empty it out and go into your machine and check the pump which is most likely clogged or one of the lines that goto the pump or drain hose are clogged send me the make and model of your machine and i can send you schematics how to disassemble if you have any further questions please message me back and please remember to rank how this opinion has helped with your appliance situation after our chat has concluded Thanks again
Rick
Dec 24, 2010 | Washing Machines
Baumatic BK6EL washing machine will not fill with water, it only lets a cup full in, shuts the water off and starts washing. Any ideas? Thanks, Mandy
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Aug 11, 2010 | Washing Machines
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove the agitator
it is a bit hard to tell you when I dont have a name of your washing machine but this is the way I use to do it so I hope this helps you dear.
ok start with the top of the agitator now if your softener goes in the middle there this part usually pulls out if it dosent it will unscrew but u will probably need a pair of multi grips to unscrew it. If the softener bit in the middle pulls out then the rest is easy just pull it up and it will be out but make sure you have no water in the machine as this will cause you grief and you will not be able to pull it out if you cant get the water out of the machine I have the soloution without turning the machine on NO POWER NEEDED just take the pump hose the one that pumps the water out into your sink
and lay it flat on the ground all water will be out or if the machine is in the house get a bucket put the hose in there then lift the hose up back into the sink empty bucket and continue util empty. hope that helps dear
Cheers from the Gold Coast
Jan 22, 2010 | Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps on stopping in the middle of the spin cycle
you will need to get some help to put the machine near your back door so that you can put the gray hose out side the door when all water is gone your door should open if not then you need to take your pump out and clean it out and then take the filter out it might have a sock or some thing clean it out and buy the time you have put it all back the door should of opened take any thing out of the drum put the machine back and put it on a program so some water can get in the machine then or put it on a rise and spin that will be a good program to put it on if the machine finnish then its all done.
Jan 06, 2008 | GE Energy Star WCVH6260F Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
78 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
