Question about AEG 24 in. Favorit 40310 Free-standing Dishwasher
AEG Favorit 420 Freestanding dishwasher
This is not draining. Water remains in the drain pipe.
I'd appreciate any suggestions
  • PicklesBA Dec 30, 2007
    I thought it could be that and methinks it's a job for a professional. I don't trust my skills in that regard.
    Thank you for your advice Colin.
I have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Posted on Dec 28, 2007
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
My 87070vi does not drain properly and then shows an i20 error and beeps continuously. what should I do?
You will need to remove the drain pump/valve , look under to remove the unit as it will be clogged with food residue. You will need to flush out with jet of water and air and then check the drain valve to work in full strength. If not the water will remain within for more time than required as the program will sense an error.
Apr 27, 2011 | AEG 23 in. Favorit 86070Vi Built-In...
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Hi, I have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Dec 21, 2009 | AEG 24 in. Favorit 60870M Free-standing...
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Oct 24, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Open Questions:
AEG 24 in. Favorit 40310 Free-standing Dishwasher Logo
603 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
