Question about Intel D865GVHZ Motherboard
It is not booting
Hello Sir
I am using Intel D865GVHZ board . when i give it to power supply
it is not bootng. SMPS is ok . while i power on processor fan moves but stops?
plz help me...
  • kjhansen49 Sep 17, 2008
    PSU is good, RAM is good. I disconnect all accessories except hd, still no response at all. PSU fan doesn't even come on. A small green light lights up on the motherboard but nothing happens.
    Keith
  • drskyler Oct 17, 2008
    System has a Lexmark all in one attached via USB. Required a reset of Lexmark which is done by unpluging the PS and reinsertion after completion of this step the CPU video had shut down. Not restartable. Removed the battery and left out for 45 minutes and still would not restart. In the paperwork we have on the board it notes some type of USB shutdown capability but nothing about how to reset the board.
    We have another board and used it to prove the PS and switches on the box are functional, but it is our last one and somehow we think it is just a matter of resetting the motherboard????
  • 23 Answers
-->if that problem is getting after installation of   operating system , then  u should reinstall os.
-->if that problem is getting  in regular , then first    replug the connectors on the mother board from power supply.     and also  check sockets of supply.,,,, observe clearly   ...
-->remove and  clean the ram  and install  ,,, check
--> and one more  chance is there ,,,,that try to keep any operating system cd in drive  then restart the pc   ,,, if  system is not shutting  down       that indicates   OS is problem(viruse crashes the OS or  OS system components..
--> otherwise   finally  remove  the total  motherboard  from ATX cabine   and  reinstall ..   check it
if all the above   solutions are not  working   then  we cant do any thing    and also  should  return to company of manufacturer.
Posted on Nov 19, 2008
    Sergeant:
  • 263 Answers
Some times that is due to a bad heater zink that colds down the prosessor so you have to be sure that is properly seat with the compound on top de prosessor to avoid air gaps that is a thermo protection from the prsessor.... than check the memory on the slots for proper attachment
Posted on Dec 27, 2007
Dear sir i have a pc with intel desktop board D865GVHZ.the problem is that when i start the pc its cpu fan is spinning also a green light is glowing bt there is nothing on monitor,this problem also occured...
Most likely the power supply or the motherboard itself is failing, I would start by replacing the power supply. Easy to do and fairly cheap.
How To http://www.hardwaresecrets.com/article/362
Buy http://www.newegg.com/Store/SubCategory.aspx?SubCategory=58&name=Power-Supplies or Buy one in a retail store like Best Buy
Comment back if you need more assistance
Aug 18, 2011 | Intel D865GVHZ Motherboard
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
My computer isnt powering up, what should i do?
r u a professional..??
assuming that ur bios is not flashed, in a wrong way..
all fuses to mains supply are ok, including all wiring circuitry..
if so check--
the system battery for above 3.0v
all smps output signals are ok..ps-on(green +5v);
pg(violet~+5v) & sb(grey~+5v); (orange~+3.3v);
yellow (+12v); red (+5v); white (-5v); blue (-12v);
ground (black~ 0v)..
the cpu..
..replace the smps/cpu/battery with standby n check..
..contact ur system admin/vendor....
Oct 27, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
RNJ VINODKUMAR
Sep 26, 2009 | Intel D845GVSR Motherboard
Power problem in intel d865gvhz
Pull cmos cell from motherbord for 10 minutes.
So all motherbord settings defaults.
Then reconnect ATX power supply connector from smps to motherbord.
If still face same issue then you need to change or repair your SMPS.it is in back top side of cpu cabinet.
Try with other smps if still same issue then your motherbord has some issue.
You can trouble shoot this issue with above step follow 1 by 1 .
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Intel D865GVHZ Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
DISPLAY PROBLEM INTEL D845GVSR
I HAVE INTEL 845GVSR MOTHERBOARD & 2.4 GHZ PROCESSOR & 1 GB DDR RAM & AND I INSTALLED WINDOW VISTA HOME BASIC PREMIUM 32 BIT & AND MY VIDEO,LAN,USB DRIVER DOES NOT SUPPORT WIN VISTA & WHEN I BOOT THE SYSTEM IT SHOWS NOTHING
PLZ GIVE ME PROPER SUGGESTION WHAT CAN DO FOR MY VIDEO,LAN,USB DRIVERS
Dec 07, 2007 | Intel D845GVSR Motherboard
Intel 815E Mother Board
Do you mean the Power Supply?
These are relatively cheap and easy to replace.
Dec 03, 2007 | Intel Motherboard
Intel D865GVHZ Motherboard Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
