Question about Goodman PHKJ048-1 Air Conditioner
Mold goodman phkj048-1
When it rains water gets into compartment where the blower moter is. water staying on floor of unit is causing mold to form and bad smells. Was unit installed incorrectly? Water seems to come from under blower motor. The coils are clean!
  • 1,420 Answers
3 places where water could be coming from, The Ground, The venting system or the Condensate. Eliminate each one by first checking the condensate piping and check to make sure it is draining to the drain. Blow thru all hoses to make sure they are not blocked. Secondly, spray with a garden hose the venting system to see if the water is entering the system thru the venting. Lastly, if this happens only when it rains, you could have a ground water drainage issue.
Posted on Dec 27, 2007
My unit blows out black soot looking stuff, and it smears when touched, and my filter is clean. What is it? And how can I get it to stop?
Carol, the first thing I would suspect would be mold in the insulation within the blower compartment. Sometimes the cooling coil overflows, causing the fibreglas insulation to get wet which in turn allows mildew/mold to form in that compartment.
Severe cases will sometimes discharge nasty stuff as you describe coming out of the ducts.
Turn off the power and remove the blower compartment cover and investigate.
Oct 01, 2015 | Frigidaire Heating & Cooling
1997 burick centry custom floors stay wet
its more likely to be the drain hole for the shuttle, were the heater gets it air feed from there will be a drain for the water to get out, can get blocked with leaves etc, you may need to get your hand down there and pull out the rubbish and poke your finger in the hole to push the debris out.
Aug 04, 2017 | 1997 Buick Century
Audi a4 that smells after it rains or car wash
Check for moisture under the floor mats.
Feb 15, 2018 | 2005 Audi A4
I have a dometic unit and i smell wath i beleve is mold. i open it up and i see mold? around the blower. how this mold form in the blades? may i get sick breathing this stuff? tank you very much.
Mold can make you very ill depending on which type of mold it is. Mold forms in dark, wet environments and can be hard to get rid of. Your a/c unit needs taken apart and each piece that has mold will need to be cleaned thoroughly and carefully before re-installation.
Jun 22, 2011 | Dometic Rooftop RV Air Conditioner
I have a 97 grand prix. When it rains water leaks in the front passenger floor board. My a/c doesn't work. When coolent was poured into it it also leaked all in the floor.
your heater core is leaking, that would explain the antifreeze on the passenger floor-as for it leaking there when it rains, there is a piece of molding that sometimes move out of place, it is under the hood on the passenger side, below the vent plate (remove the wiper blade arms, the plate for access)-the ac not working? that could be as simple as low freon, or as bad as multiple leaks, comtaminated system, electrical issues-do you mean the blower motor, because with all that moisture stuff you have going on there I wouldn't be surprised if the blower motor has electrical issues due to the flooding.
The MOST IMPORTANT THING is to fix or bypass the heater core, or you will end up needing an engine if it overheats.
Mar 09, 2011 | Pontiac Grand Prix Cars & Trucks
It rained on the unit and the gas does not come on, even though the red light is on steady. The exhaust blower and main blower stays on.
If it has been rained on the problem could be just about anything. The gas valve has a warning right on it that says if it gets wet do not try to use it. However, If you have the tools to measure ac voltage, check for voltage (24v) at the gas valve terminals. If voltage is present then replace the gas valve. If voltage is not present it is most likely the circuit board. Good Luck :)
Dec 27, 2010 | Goodman GMS90703BXA Heater
My attic Goodman Air Conditioning unit is leaking down through the ceiling drywall. What are some of the possible problems and how do I fix them?
Ours did that. It was low on freon causing ice to form on the unit in the attic. The ice would melt causing the leaking down the drywall. We had a hvac rep. add freon. Cost will depend on how much is needed - we spent about $100. Afterward, we touched the spot on the wall up with Kilz & matched up with leftover paint in the shed. Good as new!
Jul 18, 2010 | Goodman CKL60AR60 Air Conditioner
'03 Accord-water leak at rear driver side floor board
I had a similar leak on a 1995 Accord. I traced the issue to the plastic liner behind the door panel. The seal was broken at the bottom and water would leak from that to the rubber weatherstrip at the bottom of the door that seals at the plastic threshold molding. You can't really see it good until the door panel is removed. The water would drip until it puddled up enough to run over the threshold molding and under the driver's seat. This caused the floorboard behind the driver's seat to be soaked after a rain. I have resealed the plastic lining but of course it hasn't rained since. I'm confident this will solve my problem and hopefully provide you a new place to look for yours.
Sep 20, 2009 | 2003 Honda Accord
I have an intertherm split unit and it is getting water all over
hot water heater has a relief valve on it and should have a pipe going down to the floor stick your finger in the pipe and if it is wet inside the pipe that is your source how old os the water heater dry up the floor with towels and leave a/c of for 24 hours not as wet then possible crack in new condensate pan
Jun 05, 2009 | Heating & Cooling
PHKJ048-1 outdoor fan stopped
This is nothing but a bad fan motor. Probably caused by rain down pouring off the roof into the unit. Try adding channel diverters that diverts water (a lip on the edge of the roof) >!
Sep 05, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
