Question about Trendware TRENDnet TEW-432BRP Cable/DSL 802.11g 54Mbps Wireless Router (NETWTEW432BRP)
Problems with firmware.
When I install my router, everything goes fine untill it get to the verifying firmware the it tells me ERROR:112 Wrong router. I went to the web site and downloaded the other installation disks but had the same problem. I have even tryied upgrading the firmware with no solution. I have tried calling Trendnet bu they do ot call back.
  • 2 more comments
  • Anonymous Jan 02, 2008
    error 112
  • chanthru May 16, 2008
    im also hitting the same prob how to solve it
  • dado2410 Jul 05, 2008
    have same problem like u
  • Anonymous Sep 26, 2008
    initially i was able to connect and configure. when i was modifying the configuration, i did a restart of the router and at that point things got screwed up and it starting throwing the error 112. i tried reseting the router couple of times.
    Still looking, dont know if i will find the solution. I had a belkin for years which I sent it for a friend and now I am stuck with this.
Same problem here.... please someone give me a solution...
Posted on May 24, 2008
D-link DSL 2730u modem dead after wrong firmware update through wireless
Attempt to do the firmware update, again--connecting always to ethernet for firmware updates. Unfortunately, your modem may be "bricked" (unusable)--in other words, it may be time to recycle it and buy a new one.
The firmware may proved damaged--given that the incorrect firmware successfully installed (hopefully, that was prevented by the device itself--it may have output an error message or code)--or, it was installed incompletely, or the update proved corrupted.
Mar 25, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
N300 router will not allow my apple hardware to print to my air printer
Hi, yes it could be a problem with bonjour support in router, maybe you need to update firmware, the steps to do it are in the following link: Updating your Belkin routers firmware
Nov 11, 2017 | Belkin Surf N300 Wireless Router...
Printer head
The error can be the result of firmware code, printer contacts or the printhead itself failing. There is a firmware update that addresses the "Printhead Error" on your printer. Please follow the steps below on how to successfully update your printer and provide information to the following questions:
1. Open the cover to remove the printhead and tanks (if installed). You may go to http://bit.ly/klw9sJ to have a visual on how to remove the printhead. Note: Carrier will come to the center automatically with this error message as the cover is opened.
- Remove the tanks and place on a table.
- Open printhead latch and remove the printhead.
- Close the printhead latch, close the printer cover, and confirm the error message goes away from op panel.
2. Proceed with the firmware update. Please visit the Lexmark website to download and install the update. Click here to download an important firmware update for your printer. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct. Please indicate if the update failed or successful.
3. If the firmware update software notifies that you have the latest firmware version, please inspect the printhead for the manufacturing stamp (http://bit.ly/vLvfCx ).
a. Is the stamp on the nozzle plate side?
b. Is the stamp on the contact side?
4. Open cover, open latch, and insert printhead only.
- Firmly push down on printhead then close latch and cover.
- If error message goes away, continue with normal installation steps for cartridges.
- If error message remains, open cover, remove cartridges, open latch, remove printhead, re-install printhead, close latch and install tanks cartridges firmly.
5. Try to print a document again to verify that the problem is fixed.
Please feel free to contact us at LxkListens@Lexmark.com
Nov 11, 2012 | Lexmark S815 Genesis AllInOne InkJet...
Intermitent wireless connection
1. check the firmware updates for you router.
There should be a update manager in the router.
2. bring up a web page type in 192.168.0.1 then enter the user name as "admin"
no password.
3. check status page to see if you are getting an IP address.
this is not a Windows 7 issue.
4. Hard wire the router to the PC to do the firmware updates. That is connect a RJ45 cable or ethernet cable ( straight through) not a crossover.
Apr 20, 2010 | Linksys WRT160N Wireless Router
Loss of connection to internet for no apparent reason
Can you check if this happens without the router ? if you connect your modem directly does it still drop at times ? If not , see if you can update the firmware of your router. that could help
Thanks Ranjit
Oct 07, 2009 | Computers & Internet
Desktop and two laptops won't work with modem & router now
Probably you used the wrong type of ethernet cable, a crossover one. Try another Ethernet cable but this time a straight one.
Mar 11, 2009 | Westell Wirespeed ProLine 6100 Router...
Router
Does your computer connect to the Internet okay at other wireless locations? Make sure you have the latest drivers in your laptop for the wireless network adapter. You should also verify that you have the latest Windows updates installed.
Is your computer sometimes used in a business network?? If so, make sure the "use proxy" setting has been disabled in your browser when using the dlink router.
Check the D-link website at http://www.dlink.com/products/support.asp?pid=565&sec=0#firmware to verify that you are using the latest version of firmware on your router. If it has any known problems, a firmware upgrade could fix it.
Let me know if you need more details on any of these points. Hope this helps!
Jan 11, 2008 | Computers & Internet
Computers & Internet Logo
501 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
