Question about Sennheiser HDR 130 Consumer Headphones
Have not used them for a while
Battery on charge over 12 hours, turn on ear phones, no sound , no green light on xmitter
  • Anonymous Jul 14, 2008
    I am returning them because I cannot make them work....They lit up and then they stopped...seems like a loose wire
  • 3 Answers
These systems have some signal detection, so needs an input to fire it all up. That is the same for the greenlight, when initially switched on for my HDR 120.
Posted on Mar 08, 2008
Why does my ryobi 12 v battery charger light always staay red even after 6 hours of charging a battery ,never turns green
Sounds like you may have a bad battery. Does the batery seem to have a charge at all?
Nov 11, 2013 | Drills
The original battery stopped working. Whenever we picked up the phone it just made a very loud noise in our ears. Now I ordered replacements batteries from ebatts. The red light is always on, slightly...
place the phone in the BASE for several seconds then try it. make sure it is the base and not a stand alone charger. if this does not correct it ensure you have the correct replacement battery for the phone. be aware the first time you charge it ... it has to be charged for at least 12 hours
Dec 08, 2010 | Dual Maxus 5.8GHz Handset Cordless Phone
How long to charge a peg-perego 12ah battery
until the green light on the charger comes on, or 1 hour for each amp hour that the battery is, so for a 12ah battery you should charge it 12 hours
Oct 31, 2010 | Peg Perego 12 Volt Rechargeable Battery
The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Aug 29, 2009 | GN Netcom GN 9350 Wireless Headset
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
May 11, 2009 | Invacare Pronto M51 Power Wheelchair
Short time between bluetooth charges
You should have up to 4 hrs talk time, and 180 hrs of standby.
Make sure you charge the 2050 until the l.e.d. turns off. As long as the light is on, its still charging.
If you did that, I would return the unit for exchange, your may have a defective battery.
Mar 17, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Turning on my hs815
Battery is charged when the light turned from amber to green. After that, place bluetooth in ear and hold down on button until you hear a beep. You can also hold button until you see a light flash. If that doesn't work, try a different charger.
Nov 14, 2008 | Motorola Mobility HS815 Wireless Headset
I charge my LG KU990 full over night within 12 hours the battery
You just have to charge it fully but not for long as soon as it turns full battery then swithch ur phone off then take the battery out for a sec then put it back on then turn ur phone on then it will work for a longg timeee kk..
Nov 13, 2008 | LG KU990 Viewty
Sennheiser HDR 130 Consumer Headphones Logo
903 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
