Question about Toshiba SD-V392 DVD Player/VCR
Toshiba SD-V393 After thunderstorm, would not power on. Fuse inside is not blown. Disconnected power overnight, reconnected power - still will not power on.
  • 286 Answers
It's blowed up REAL good.
Do you have a volt meter? If so, measure the power outputs of the power curcuit.
This won't really help, since if you measure the power and it's good, something on the rest of the board is bad. If the power is not good, you have to repair the power supply. If you don't know anything about electronics troubleshooting and soldering, there's no point to trying.
There is no simple owner doable solution to a problem like this.
Posted on Feb 14, 2008
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
Main alternator fuse for my '92 Toyota Paseo constantly blows out when I reconnect my red battery connection to red battery post. Why?
carefully disconnect the alternator completely, now reconnect the battery, now one by one reconnect the alternator carefully first the connector check is fuse is blown, now the big wire that charges the battery if the fuse blown when the alternator was disconnected, the problem is in the wires, an accident, a mice, a recent engine job.
The fuse blown when the terminals to alternator are connected the problem is the alternator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Jan 03, 2011 | 1992 Toyota Paseo
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Soyo TFT 19" LCD Monitor
We had a thunderstorm and my thermostat died (carrier), now my upstairs unit is not working!
You amy have a blown fuse in your AIr Handler. There is a small 5 amp auto fuse on the fan board on the inside unit. You can replace this yourself. Just open up the panel and you will see on top a solid stae board with a 5 amp fuse plugged into it. Shut off power before you do this ok. Rud
Jul 18, 2009 | Heating & Cooling
Toshiba DVD player will not power up - totally dead, but fine last time it was used
Either the fuse under the cover is blown, or your power supply is shot. check the fuse first, by removing dvd cover.
Jan 30, 2009 | Toshiba SD-3980 DVD Player
Sound cut out.
If it will turn back on then it is not a simple blown fuse. If you heard it 'POP' then I would take an educated guess and say that the integrated output amplifier module has blown. You could try disconnecting from the power and taking off the lid and checking to see if there is any physical signs of damage, but, unfortunately there usually isn't. Without electronic knowledge it will be difficult to pinpoint and trial and error replacing parts can quickly become economically unviable. Sorry and Good luck.
Oct 06, 2017 | Yamaha RX-V393 5.1 Channels Receiver
Tv Fuse Blown
Depends on how hard the fuse blew. If softly, perhaps 1 amp diff is too much.
If hard - blackened inside - then you need to call in a tech.
Mr Bob
www.imageperfection.com
Dec 22, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Setting the clock on my dvd/vcr
Here is a link to your owners manual: http://www.tacp.toshiba.com/tacpassets-images/models/SD-v393/docs/SD-v393_om_e.pdf It explains how to set the clock on pages 24-26.
Mar 25, 2007 | Toshiba SDV393 DVD Player/VCR
Toshiba SD-V392 DVD Player/VCR Logo
257 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
