Question about Samsung SGH-U600
Profiles I do not seem able to edit profiles.....add my own messeage alert etc.
  • 425 Answers
Try resetting your phone to factory settings...
Posted on Jan 02, 2008
Sound is not working on tour9630
Internal speaker sound volume is controlled by the rocker switch on the right side - directly below the headset jack. This will control both the private listening mode volume level and the volume of speaker when Speakerphone (or MP3 audio) is selected. The speakerphone mode is toggled on and off by pressing the "$" key (to the right of the "M" key).
Ringer volume is controlled by first selecting one of the seven customizable profiles under the speaker icon on the top left of the screen (below the battery gauge). Move the cursor to highlight the speaker icon and press the track ball. Choose the desired profile: Normal, Loud, Medium, Vibrate Only, Silent, Phone calls Only or All Alerts Off. Repeat the process - but this time scroll all the way past the profile list - and choose "Edit Profiles" instead. Here you can select the profiles one by one (or even add a new one) to customize them to your liking. You decide the sound, volume,etc for all the alerts for each profile. It provides a huge amount of customizing choices.
Finally, you can freely download the 314 page Blackberry Tour 9630 User Guide to learn about all the functions and tips using the phone.
Please rate my reply if it was helpful. Thanks and good luck!
Oct 05, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
How can i activate new ring tones and text alert tones on my sony ericsson satio phone ? also when trying to download apps it sayd redownload and when i do it shows an error !!! any help would be so...
you can set a ring tone in play view!
hope this helps please remember to take the time and give me a good rating if you appreciated my help.
Managing tracks in play view
You can manage your tracks in many ways when playing them. You can, for example,
delete a track, send a track, set a track as your ringtone or add a track to a playlist.
The following icons may appear in the touchbar when a track is playing:
Exit the play view and go back to the previous level
Go to the music library
Adjust the volume
View more commands
Delete the current track
Send the current track
Set the current track as your ringtone
Add the current track to a playlist
View track information
Minimise the music player
To delete a track
1 When the music player is open, tap > .
2 Select an option.
To send a track
2 Select a sending method.
To set
also can be done in personal settings:
Personal settings
You can personalise your phone by changing the standby screen, profile or themes.
Profiles
You can change settings such as the ring volume and vibrating alert to suit different
locations. You can create new profiles or change preset profiles.
To change the profile
1 Select Menu > Settings > Personal > Profiles.
2 Tap a profile and select Activate.
3 Select Back.
You can also press and then select a profile.
To edit a profile
2 Tap a profile and select Personalise.
3 Change the settings and select Back.
To create a new profile
2 Select Options > Create new.
3 Enter the settings and select Back.
Mar 26, 2010 | Sony Ericsson Satio Cell Phone
Changing ringtones and alerts on sony satio
I believe that you go into settings/personal/profiles. There you can highlight an existing profile or create a new profile. When you highlight a profile you can select option button, then tap personalise and this with give you options to change ringtones, ring type, message alerts etc. Hope this helps
Nov 02, 2009 | Sony Ericsson Satio Cell Phone
How do I stop the annoying ring tone for every email I get on my
Under your profiles options (normal/quiet/vibrate etc). scroll down to advanced, choose which profile you want to edit alerts for and the alert list (call, email, SMS etc) should come up.
Sep 01, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I would like to stop all sounds that alert me that I have recieved an email. I have a Blackberry Curve 8330
Go into your Profiles ------>Advanced ------> Edit ------> SMS Text ------> Tune.
All of your alerts are set via Profiles. Just make sure that you're editing the active profile.
If this is not what you were looking for please leave a comment and I will get back to you =)
Jul 15, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
No message alert tone
You will need to access Profiles>(Whatever 'Profile' you have defaulted you will need to edit) Use your options button and access 'edit'.
There will be a list of all your features that you customize any sound for. When you seeing Messaging, access that feature and personalize your on alert.
Hope that helps! Thanks.
Mar 17, 2009 | RIM BlackBerry ® 8830 Cellular Phone
I need help with volume
You may have selected a profile that does not alert you audibly when you receive messages. You may select a different profile, edit the current profile or create a completely new profile. I'm attaching instructions for creating a profile and editing would be similar except you would select a profile then select "edit" for the menu. Be use you have "tone" or "vibrate and tone" selected and that the volume is not on mute. Always save your changes.
Create notification profiles
1.In the profiles list, click the trackwheel.
2.Click New Profile.
3.Type a name for the profile.
4.Click an item.
5.Click Edit.
6.Set how you want to receive notification for that item.
7.Click the trackwheel.
8.Click Save.
9.Click the trackwheel.
10.Click Save.
To turn on tones when pressing the keys, follow the following instructions:
Turn on tones when pressing keys
In the device options, click Screen/Keyboard. Set the Key Tone field to On. Click the trackwheel. Click Save.
Jul 20, 2008 | RIM BlackBerry 7520 Handheld
How to change ringtone on samsung sgh-j700
1. In Idle mode, press <Menu> → Settings →
Phone settings → Phone profiles.
2. Scroll to a profile.
3. Press <Options> → Edit → Voice call ringtone.
4. Select a ringtone category → a ringtone.
5. Press <Options> → Save profile.
May 04, 2008 | Lands Phones
Samsung SGH-U600 Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
