Toshiba 50H82 50 in. Rear Projection Television
Problem for Toshiba 50H82 50 in. Rear Projection Television
Hi I have a toshiba 50h82 tv that is 7 years old
By jenniferpye on Oct 12, 2009
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem our tv picture has been very dark I have tried adjusting the picture but in weighing my options to fix or not is this a seperate problem then the convergence?
Solution #1
posted on Oct 12, 2009
Not Rated)
Abrsvcs
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 88%, 1882 votes
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Was this helpful?
Yes
No
Popular Solutions for Toshiba 50H82 50 in. Rear
Questions and Unsolved Problems for Toshiba 50H82 50 in. Rear
Do you recommend Toshiba 50H82 50 in. Rear Projection Television?
Answer
Answer
is there a certain number of pins that I need for the HDMI cable?? I see different ones around
Answer
my toshiba 50h82 tv screen jumps then after 20 minutes the picture shows clear
Answer
The picture disappeared during a film as if a tube or bulb had popped. We can't turn the tv on... (More)
Answer
When I go to turn on my Toshiba 2005 Projetion TV it turns off after a couple seconds. Then it turns... (More)
Answer
My 52'' Toshiba Rear Projection TV is displaying alot of red & there is a thin turquoise... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , CO
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
