We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden. There is no picture (no blue screens, no menus, just black) and no sound. The green light on the front of the set labeled "timer" comes on and will not go off. I would really appreciate any suggestions--I don't want to overreact and replace the TV if this might be a simple problem. Thanks so much.
When I turn on my WS-65807 it clicks on then about 4 secs later it turns off. No pic comes up before...
(More)
When I turn on my WS-65807 it clicks on then about 4 secs later it turns off. No pic comes up before it shuts itself off
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up....
(More)
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up. When I try to turn it on the green led stays on for a few seconds, then goes off.
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just...
(More)
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just changed the IC's because of a convergence issue, but now the tv won't come on. The fuse is F9A05 and when I check for a code I get 2-2 or short protect. What should I be looking for that would cause this fuse to blow? The fuse is located on the power board where most Mitsubishi fuses are. I have never had bad IC's from the start, but might that be the case here? The green light on the tv would blink 3 times and the tv would turn on, but turn right back off. I replaced fuses F9A05 and F9A04 and seemed to fix the problem. Then I turned the tv off to put everything back together and it wouldn't turn on after that. So before I left the plan was to replace the fuse and not turn the tv off, but that only lasted 5 minutes. F9A05 is connected to diode D9A61 (where I think I should be seeing -24v, but don't know how to check that unless you need to test the tv under load) and pin 22 of power transformer T9A50. Please help me if you know what the problem is.
