Televison & Video Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence problems how do I get to service menu sony kp53hs10
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Oct 12, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564298
Points
12312
Typically, you shouldn't need to access that menu. Once the settings are saved by the factory, any adjustments can be made from the user menu. If those do not resolve the problem, then the likely issue is a failure of the convergence ICs or the connections at those ICs. Are you seeing what appears like a 3D image with bowing at the top and bottom? If so, then try resoldering the pins of hte convergence ICs first. That may resolve the problem. If not, then change the ICs. Report your results here.
Thanks,
Dan
I have a sony KP53HS10 Projection TV, and I have double images. There is a ghost image that is usually yellow.
Normally this problem is caused by lens unit. relapse and check it. please contact your nearest authorize service person that is the best
Where is the convergence button on a Sony 46?
you will have to use the menu, it should have auto convergence settings. if not the service manual would be needed to get to the service menu.
10helpful
2answers
Sony kp 51ws510 convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Convergence problem with sony
try to adjust the image revision on the customers menu.
Sony KP-51HW40 Convergence issue
Can you adjust the convergence by the convergence menu without going through the service menu? The settings through the convergence menu should save automatically. Have you replaced the convergence ICs? If so the settings should save, if not the D board will need to be replaced or at the very least rebuilt. Let me know if you need further assistance with this issue.
I have a convergence problem
Here is a source for the service manual in pdf fromat. $15
www.user-manuals.com/service-manual-SONY-KP53HS10.html
3answers
2answers
I have sony 53 Projection TV Model No KP53HS10
First check the batteries in your remote. if that doesn't work check the setup menu. see if you have any kind of auto on\off, alarm, snooze or enabled. some of Sony's tv's had these features
Blurry picture
I Just had the same problem with my Sony KP43HT20, was a blury picture with the red & green going bad.......My set had defective convergence IC's, they are known to go in Sony's..IC's run about $30 a piece. Good Luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
