Question about RCA F36650 36" TV
Rca has sound but no picture
Tv comes on but no picture. tube light up in back.
  • 35 Answers
Do you have a old tv? if you do nothing might help, if you dont then does it have audio and video plug ins that you need?
Posted on Dec 26, 2007
RCA DLP tv, the picture goes blank after a few minutes, and then comes back on and goes back off again...
Take it back to the store. If warrenty is expired then you will have to get a new TV or send it for repair . I don't know of anyone that comes to your home for TV repair. Sounds like picture tube is out of it.
Aug 17, 2013 | RCA Televison & Video
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
The light stays on but there is no pictue or sound
picture tube shot or conections to the tube faulty take to a tv repairman
Jun 21, 2009 | RCA 24V412T TV
MY TV WILL NOT STAY ON WHEN TURNED ON!
Pull the back off disconnect the CRT Board connected at the end of Picture Tube if TV comes on with sound then you have a Bad TUBE.
Feb 15, 2009 | Sony KP-61V90 61" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
NO PICTURE
Adjust the two settings on the back of the flyback with a phillips screwdriver...
Dec 16, 2007 | RCA F32650 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
