Thank you for using FixYa,
You can't change the messaging tone to a song from your music playlist, these options for choosing your own music as ringtones are restricted to an alarm tone, phone ringtone and caller ringtone (caller ringtone is when specific people calls you, a certain ringtone would appear for that caller to differentiate between callers)
However, you can change your message ringtone to certain ringtones for your Galaxy S phone by going through the following steps:
(P.S I am assuming that you are using the stock Samsung SMS application)
1)
Go to your stock Samsung SMS app (it's named as 'Messaging')
2)
Press the softkey 'menu' button
3)
Go to settings, scroll down and from there you can see the option 'select ringtone'
If you have version 3 software there is no way that you can use mp3 or downloaded tones as message tones, best thing you can do is upgrade your firmware to version 4. Type this on the dial screen to check your version *#8375#
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
After you record a sound and save it go to message then picture message and attach it to the message. then send the message to your own number for Example if your number was 855-555-9999 you would send it to that number
After you get the message go to options and save sound as ring tone.
Hi Jane, To put mp3 files as message tone you have to download a .mid file and put it in with all of your other mp3 files. once you have done that go into settings and go to the message tone settings. press use my effective alert tone or what ever it says and click play on the .mid file the just go across and find the mp3 you want but dont go out of the play mode until you select the mp3 you want. im glad i could help.
First you have to go to menu>my stuff>tools and utilities>voice memo>and you record a voice. When you are done recording, save it then go to menu>settings>profiles. Now you press the options key on profiles and go to customize and you click. Scroll down to message sound and click on it. Choose audio>my voice>and choose the recording that you want to be for your message. Press options>select. You should then be taken back to your messaging and ringtone settings. press the options>save.
Alas, the V750 doesn't allow you to manually add ringtones that way. The only way I've found to add a ringtone to my V750 is to email the ringtone as an attachment to my phone, then choose to save the file as a ringtone.
Every Verizon number comes with an [email protected] email address, which comes across as a text, video, or picture message on your phone. Just replace the x's with your phone number.
NOTE: Be aware that when you open the message, your ringtone will begin playing; you probably don't want to do this at work!
