Question about Hotpoint HSS25GFP Side by Side Refrigerator
GE Hot Point side by side Refrigerator
Ice Maker is fine, but no water comes out, could be one of the following:
1. Frozen water line - just unplug?
2. Bad water line valve - Where is it?
3. Bad solenloid - What is a solenloid, where are they?
Please help!!!!
  • 146 Answers
Okay this is pretty easy to find. Just trace where your water line comes into the back of the refer. You may have to remove the back panel. As you trace it in you will see where it comes to the valve. The solenoids are on the valve, one for the water (if you have water and ice in the door) and one for the ice maker. Both solenoids are on the same valve. If your ice maker runs and dumps fine and you don't have any water on the floor then it is your valve (water side) even though your ice maker is fine you may have to replace the whole valve as it is one unit.
Posted on Dec 26, 2007
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
On a GE side by side where is the water reservoir
I had the same problem. The line is frozen. GE will not admit there is a problem. I read a suggestion on line & followed up on it. I placed styro foam insulation on door inside the freezer compartment & no more frozen line & water flows freely.
Jul 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
