sheck the back wall of the freezer where it sits in that trough, more often than not this complaint is the fault of a defrost drain. if you can try to remove the back panal on the freezer, if its a defrost issue there willl be a huge amount of ice behind that panal blocking the defrost drain.
after you chip what you can away, you'll find that a hair dryer and hot water are the best way to get that drain clear so it wont happen again
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag MSD2454G Side by Side
my maytag refrig/freezer side by side started leaking water from the inside and now does not make...
(More)
my maytag refrig/freezer side by side started leaking water from the inside and now does not make ice
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer...
(More)
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer some type of coil or element red hot like the element in the stove. And the water was running down from the back of my freezer, to the front of the fridge and leaking on the floor. It happens every few hours. What should I look to replace of repair? Model # is MSD2756GE
(More)
