Question about Pioneer VSX-D508
Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
All speakers work (2 large front, 1 small ctr, 2 small surround). The front and center speakers are very loud - the surround speakers are so low you have to be standing beside them to hear anything. I have tried to adjust the speakers with the remote control as stated in the manual but all it does is increase/decrease the volume on all speakers. What am I doing wrong?
  • missy101 Dec 27, 2007
    The problem seems to be solved. My brother came over last night. After I told him there was no surround sound, he started working on the unit, making sure all the connections were right and then adjusting settings with my remote control. It started working. The connections were right but I guess the setting were wrong. I don't know what he did, but the surround sound is now working. Thanks for your help.
Receiver on the screen displaying power off
Posted on Apr 15, 2008
Can't get the subwoofer to work
try setting the front speakers to 'small' in the setup menu. some models of pioneer receivers disable the subwoofer output if the fronts are set to large
Feb 18, 2015 | Pioneer Vsx-d457 A/v Receiver-5.1...
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
How do i connect an equalizer model gr-408 to a receiver vsx-d508
In any tape loop (MD/Tape 1 or Tape 2 Monitor), OUTs to INs, BUT it will only be useful for stereo analog sources as activation of the loop disables any digital audio inputs.
Aug 14, 2011 | Pioneer VSX-D508
I have a Pioneer VSX-D308 reciever and I have a EQ. How do I hook it up to this reciever?
I only know of one way to do this and here it is:
1. Plug your tape deck's output (cassette or R2R) into the EQ's "Line In".
2. Plug the EQ's "Line Out" into the Receiver's "Tape 1 Input".
3. Now plug the Receivers "Tape 1 Output" into the Tape Player's "Line In".
4. You have now made an "FX loop" for the Tape Deck. Now you just have to put the Tape Deck on "Tape Monitor".....put the Receiver on "FM"..... and turn on your favorite FM station and you will hear the FM Receiver THROUGH the tape deck's "Monitor Send" AND the EQ.............set EQ to taste....... and BINGO.......DONE!
Jun 09, 2011 | Pioneer VSX-D308 Receiver
Everytime I use the DTS functions to enable my surround sound, no sound goes to my speakers. I am able to use it only for the standard output with the left and right front speakers. What could be causing...
DTS should be enabled only if your source has a DTS digital audio out connected to the receiver.Mostly only DVD / Bluray players have DTS sound and is outputted through an optical or co-axial port on the back of the player. Its a multichannel digital encryption technology where the signal is sent through one cable and your receiver decodes it into 5.1 or 7.1 channels according to the source.
Apr 22, 2011 | Pioneer VSX-D810S Receiver
Hello, i have a pioneer vsx-d508 receiver, and i cant get any sound from it the thing works but no sound i tried everything the manual said to try but still nothing ,,can someone help me or point me in the...
Is this new or was it working for a while and then failed? Does it otherwise look 'normal'?
Use FM as the source to test because it doesn't have any way to miswire it. Turn the volume to something less than midpoint so you don't blow the speakers when the aha moment arrives.
Look for an unwanted Tape Monitor or Mute activated. Speakers enabled. FM selected for t his test.
Jan 17, 2011 | Pioneer VSX-D508
Pioneer Receiver VSX-D508
I just set it to theater1 setting and it made the center speaker still no sub but the reciever has plenty of base.
Apr 12, 2009 | Pioneer VSX-D508
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Jan 23, 2008 | Audio Players & Recorders
Pioneer VSX-D508 Logo
875 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
