Question about Canon FaxPhone L75 Plain Paper Laser
Paper feeding the original.
When feeding the original, the paper is pulled unevenly from the beginning and damages the original.
  • rmattson Dec 08, 2008
    Mine doesn't feed; it feeds only one side and then stops. It is like there is something in there stopping it but I can't find it.
    Scholar:
  • 159 Answers
A number of solutions. Open the transmit cover and examine the paper path for obstructions, "white out" and alignment of the rollers. The exit roller is the last roller and is prone to become misaligned due to the attachment points on the lower transmit tray being actually broken. I have even seen this on so called "B" stock or warranty repaired machines right out of the box. It happens when a sheet of paper gets stopped and someone pulls it out instead of opening the transmit cover to do it. Also, sometimes the transmit cover doesn't close properly. In this case make sure it does close by using 2 hands to do it.
Posted on Dec 27, 2007
Uneven paper feed
probably best to use a different paper brand or grade of paper. try using a different feed if possible, there is usually 2-3 different feeds on these multi stations now days. (front, top and rear)
Feb 15, 2013 | HP Officejet Pro L7650 Printer
It pulls papers in unevenly...
Your paper feed rollers probably have paper dust on them. Clean them with a soft cloth (not paper towel) moistened in alcohol. Then your paper should feed evenly.
Feb 18, 2011 | Lexmark Office Equipment & Supplies
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
Lexmark 7675 paper jam
> feeds unevenly
Usually, there are two, maybe three, rollers that should _evenly_ pull the paper through the path.
Check that each roller is making good contact with the paper.
> out of paper error-message
There's a small sensor, and usually a "finger" that rises when the weight of the paper is not sufficient to hold the finger down. Check for "dust" clogging/blocking this finger.
If all else fails, it's time to take the printer to a qualified technician, for a professional cleaning & tune-up.
Apr 16, 2010 | Office Equipment & Supplies
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon FaxPhone L75 Plain Paper Laser Logo
old marine
old marine
