Question about Lexmark X1270 All-In-One InkJet Printer
Scan bar not moving
I just got it brand new. Have installed everything. The printer works fine but when trying to scan it's like the bar gets stuck as it doesn't move and just makes clicking noises.
SHALOM H, HOLA, NO CONSIGO QUE FONCIONE EL SCAN? GRACIAS
Posted on Dec 29, 2007
1410 does nothing when i scan
Check for copying, if its fine no problem with the printer, check system side..If copy also blank replace scan head..pl revert us for further advises
Jan 01, 2012 | HP PSC 1410 All-In-One InkJet Printer
I have a Brother MFC 8440. The scan bar has stopped functioning the bar deos not move to scan the documents. It makes intermittant sounds but seems stuck in its resting place?
If the device was moved without the light bar being locked prior to moving, it is possible that the light bar was knocked out of alignment and it will not work. It is very important to lock the light bar prior to moving for that very reason. I would suggest you take the device to a qualified specialist to identify the issue.
Nov 04, 2011 | Office Equipment & Supplies
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
HP Photosmart C4580 wont scan
It seems that scanner glass is not glowing or may be bulb are not moving properly.
you can try these thigs:
1)Turn ON the printer unplug the powe cable from the back of the unit; wait for 30secs; replug the power cable.
2) Try this to check teh funtionality of hardware Load letter or A4, unused plain white paper into the input tray.
  1. Press and hold the Cancel (c01235250.gif ) and the Start Copy Color buttons at the same time.
  2. Release both buttons. The self-test page prints.
3) Now check if its copying or not?
It will work fine(if your printer scanner glass is fine)
You can also try scanning from computer(if installed)
the location of file would be=
c:\program files\hp\digital imaging\bin
here locate for file "hpqscnvw" hit it and try to scan
Best of luck
Jul 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
Will not let me scan documents
install the software first and then you will be able to scan its just that the scan options are not getting detected from the software on the computer that assigns the scanning options.
IF the software is installed then open hp solution centre and point to settings.Then point to scan settings and click on scan to setup and move all the items on the left to the right by selecting each one and pressing the right arrow button and click on ok and now check you will be able to scan
Jun 15, 2009 | HP Officejet 7210 All-In-One InkJet...
Cannot get scan bar to move
It sounds like the scan driver is malfunctioning. Reconnect both ends of your printer cable. If that does not work, uninstall all of the Lexmark software from your computer and reinstall.
If you are an advanced user, you could first try just removing the Lexmark printer from the Windows Device Manager.
May 19, 2009 | Lexmark X6170 All-In-One InkJet Printer
Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
May 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark aio will not scan does everything else!
all these problems seem to be with Lexmark equipment
Dont see any Epson problems, story here somewhere
Feb 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1150 printer-fax
Try turning the unit off to reset it and see if this corrects issue.
Dec 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
New installation 810, printer works A1, scanner won't work
Uninstall and reinstall the software. Normally the software installed on the computer controls the scanner functions for the all in one dell stuff. Check dells site also for any updates that might correct this issue.
Jul 08, 2007 | Dell 810 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
