Question about Canon MultiPASS MP730 All-In-One InkJet Printer
MP730 printer Canon
Pictures are not coming out good. When I do printer heads alignment , in column D and E there is nothing there
Warning: This can be messy. Covering your counter or table and wearing thow away plastic gloves is strongly recommended. Take all the ink cartridges out. Wipe the rims of the ink ports and seal with tape or peel & stick label, to stop them from drying out and set aside. Flip up the plastic lever on the right side of the ink cartridge holder box. This will release the hold down mechanism that keeps the print head in solid contact with the electrical contacts at the back of the ink cartridge holder. Gently lift out the actual print head. You may have to gently use a straightened out paper clip to rock it out so you can get it with your fingers. Get a small plastic tub (cottage cheese or yogourt container) etc., and soak it in rubbing alcohol for an hour or two. Put enough over it to also soak the ink screens on the other side from the printing part of the head. Clean gently with a Q-tip and alcohol. Inspect the bottom side with a magnifying glass if available, and get any dried ink off. Change the alcohol and do this again until all ink is gone. Finally, shake the alcohol out over a newspaper (watch, i'ts messy) and leave overnight to dry. Clean the gold dots with alcohol just before you put it back in. It is important not to touch the gold or the actual printing part of the print head. Put it all back together and run a few head cleanings thin a nozzle check. If the problem persists, call Canon and order a new print head. Approx. $60-70. Good luck.
Posted on Dec 29, 2007
I have a Canon MP730 and it has always worked great - until. I ran out of black ink and replaced tank. Tried to align the print head, but none of the black samples are even close to being a solid color -...
Hi There,
I believe that the printer head which feeds the ink dried out and clogged at the ink dispersal point. I'd suggest you take it to your nearest printer service capable repair center and just have them unblick the clog.
Regards,
Selk
Mar 25, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Cannon multipass 730
Try reseating the printhead. Remove the ink cartridges, lift up the lock lever and then pull the printhead out at an angle (IIRC). Then reinsert the printhead and lower the lever. Then reinsert the ink tanks one by one; Press down until you hear the click. Close the scanning unit and hit Set to print the alignment page. Tell the printer which line in each column has the best print quality (most solid); this is the horizontal alignment. Then repeat for the vertical alignment.
Try resetting the printer (on/off cycling). If this doesn't work, you may need a new printhead. Unfortunately, this may not solve the problem and you may need to have the unit serviced. Printheads are not returnable once you install them (so if replacing it doesn't help, you are stuck with the spare.)
Good luck. I hope this helps.
Jul 22, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Lines appear on pictures when printing
Please align your cartrigde and clean the heads using the printer program
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Waste ink near full
Try this Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
May 16, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Missing Column G on print head align printout!
can you please try a test page...and report back what that looks like..
Oct 15, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
