Question about Canon PC-400 Color Copier
Power problem We have a Canon PC-400 copier. A user reported a white streak on a copy. I powered up the copier and the symbol for a paper jam lit up. I powered the unit off. I checked both sides of the copier for any jammed paper. There was none. I slid the glass all the way to the left and opened up the compartment where the toner cartridge sits. There was no jammed paper in sight. I closed the compartment and slide the glass to its home position. I pressed the power button. Nothing happens. It will not power up. I have changed the power cord; changed to a different power outlet; opened and closed the comparment; slide the glass left to right a few times; pressed the power button several times, etc. Nothing happens. Any suggestions?
  • hmethot Dec 26, 2007
    That worked. Thanks.
    Problem Solver:
  • 6 Answers
The left side door is open
Posted on Dec 26, 2007
Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
Whit
Item, Inc
Aug 18, 2010 | Canon C130F Black and White Copier
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Orange warning symbol on my Canon PC745.
have a look for a piece of paper stuck over a sensor or a sensor flag broken or stuck, thats why it still thinks it has a paper jam in it
Sep 27, 2009 | Canon imageRUNNER 5000 Copier
White streak on paper using a hp laserjet 3030
I am not to fimiliar with this model. But, somewhere around where the toner is put in, should be a **** of glass shielding the laser from the toner. Clean that glass, it may have a small cover with a screw in the cover. When the glass gets toner speck on it void spots in the copied/printed images.
Apr 14, 2009 | Canon PC-400 Color Copier
Canon pc920 black and white copier white streak on copy
PULL OUT THE TONER CARTRIDGE AND SHAKE IT, IF THAT WORKED A BIT BETTER THE CARTRIDGE NEEDS REPLACED.
Apr 07, 2009 | Canon PC-920 Black and White Copier
Paper jam at fixing unit when copying page with black border and complete tx fax function the tx report will comes out
Does the black go all the way to the very edge.ALL copiers have a void area around the edges of the copy....to prevent the copy from sticking to the fuser roller, which operates at nearly 400 degrees while copying.The void area can be as much as 6 mm all the way around, that is to say, all 4 edges.without the void area, the copy will always jam at the fuser or fixing unit.Good Luck
Mar 26, 2009 | Canon imageRUNNER 400S Copier
PC745 error code - what is it. Source for manual?
that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Dec 27, 2008 | Canon PC-940 Black and White Copier
The ink cartridge in my Canon - PCII is stuck.
put off your copier. kindly look at the side where your paper exit , u see an opener, this will open the copier. then draw the cartridge
Dec 05, 2008 | Canon PC-940 Black and White Copier
Red symbol appears. not copying.
Need more information. What does the red symbol look like?
Wrench? Paper jam symbol which kind off looks like a pair of scissors?
Need more info.
Thanks.
Feb 14, 2008 | Canon PC-950 Black and White Copier
Canon PC-400 Color Copier Logo
59 people viewed this question
old marine
old marine
