Removed one bad power suply, but the second one still shuts down the server after 1 minute. Is it also bad or what? or is it some kind of protection...? I also tried reseting the bios...all disks removed...managed to see the temp of cpu -> 61degres I believe its ok?
CPU temp is OK
Look inside when it is running and make sure all fans are spinning.
If server is connected to a UPS / battery disconnect it and plug it directly in the outlet.
Try another wall outlet.
Disconnect any unecessary internal or external components.
Remove RAM and test with one module at a time.
You could have some burnt capacitors on the motherboard.
Examine them and make sure that their tops aren't cracked or bulging.
You could have 2 bad power supplies or insufficient wattage.
eBay should have parts if you need them.
Sorry if this is obvious but I have to say that that server is very old and this may only be the start of your problems. Make sure your backups are solid and try to replace it soon.
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the...
(More)
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the HDD not found. Can you solve this?
i have a raid controller (ServerRAID-61, Brodcom UNDI PXE-2.1 V7.5.14) on eServer 226. this morning...
(More)
i have a raid controller (ServerRAID-61, Brodcom UNDI PXE-2.1 V7.5.14) on eServer 226. this morning the system was down, when tried to boot up, i get 1962 operating system not found. and also give message No SCSI Controller 3E21"
When I turn off the machine and turned it on again cause it crashed a lot repeatedly until weindows...
(More)
When I turn off the machine and turned it on again cause it crashed a lot repeatedly until weindows came on the screen. when i downloaded or installed any programs but cause it crashed a lot. how can i fix it?
