Removal of the pulley requires extreme care. There is a small opening on the side of the black motor housing to allow a special tool (or a screwdriver) to fit on a slot on the armature to keep it from rotating while the pulley is unscrewed. You MUST NOT touch the magnet wire on the armature. If you nick or break it, the motor may fail.
The only other method requires the motor case to be seperated to permit you to hold the armature while unscrewing.
I have a Kirby and I used an attachment on it and replaced the belted portion back on and it is not...
(More)
I have a Kirby and I used an attachment on it and replaced the belted portion back on and it is not turning on now. What do I do?
I just need to get one cleaned and a wheel the other. Is there a store in cr i could go check it...
(More)
I just need to get one cleaned and a wheel the other. Is there a store in cr i could go check it out?
We had a store i used all the time in DSM. Just want to find one here
Electrolux Oxygen Upright 5035: Shut down after 5 minutes of normal cleaning with hose. Power to...
(More)
Electrolux Oxygen Upright 5035: Shut down after 5 minutes of normal cleaning with hose. Power to switch OK with Fluke Tester. Neither vacuum motor or the brush elevator works.(2 different switches)
where can i fine a belt for hoover upright cleaner model c1433 ? ser.#020000010952 , belt 44783a6...
(More)
where can i fine a belt for hoover upright cleaner model c1433 ? ser.#020000010952 , belt 44783a6 and 120 v 60 hz.
