Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Error Message 2738 ipod shuffle install
Error message 2738 VB script not installed. Thought I needed updated quick time spent an hour and 1/2 on down load got the same error message. I have windows vista...what a piece of shit for an operating system. Got my daughter this ipod shuffle tried to down load software. I have dial up took 3.5 hrs and then got this error message.
  • 35 Answers
Re: Error Message 2738 ipod shuffle install
If you are using windows xp then you should download this fix from the microsoft website.
If you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Posted on Aug 17, 2008
  • Apple Master
  • 13,433 Answers
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Posted on Mar 28, 2008
0 characters
3 Points
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
You can choose either to update or to restore the iPod shuffle software.
If you choose to update, the software is updated, but your settings and songs are not
If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
I found this on the ipod forum on Apples website. See their site for any further assistance.
Sometimes you can resolve it by doing the following:
- Download the .exe file from
- Go to Control Panel > Add or Remove Programs
- iTunes > Remove
- Open C:\Program Files (default location)
- Find "iTunes" (default folder name)
- Shift + Delete > OK
- Run a registry cleaner, such as PC Tools Desktop Maestro, to remove all old shortcuts and registry keys no longer valid on your computer.
- Start > Shut Down > Restart your computer
- Run the iTunes install program
This should fix the problem, however may require also to update your Windows software ( and download the latest Visual Basic Runtime executable. One time during my clean reinstall the iTunes software mentioned an error with a vb run executable and couldn't continue the install until I found it online.
Dec 30, 2008 | Apple iPod MA446LL/A MP3 Player
I found a way to solve this, you have to google for a program called ipod reset utility or, you can search here:
Either way, install, follow the instrucions and you can probably save your ipod (note; I saved my ipod on a mac. Haven't tested transfering songs from my PC an this moment)
Sep 09, 2008 | Apple iPod shuffle MP3 Player
To fix unknown error 1418
install itunes
May 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle
You should do a restore:
How to restore iPod shuffle
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect iPod shuffle to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod shuffle in the Source pane and you will see information about it appear in the Settings tab of the main iTunes windows
  6. The Version section tells you whether iPod shuffle is up to date or needs a newer version of the software.
  7. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  8. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  9. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present a message instructing you to leave iPod shuffle connected to computer to complete restore process.
  10. During the stage 2 of the restore process, a green LED will flash once on iPod shuffle, then amber and green LEDs will flash briefly, and finally the amber LED will begin to flash continuously. It is critical that the iPod shuffle remains connected to the computer during this stage.
  11. After stage 2 of the restore process is complete, the iPod Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dec 29, 2007 | Apple iPod shuffle MP3 Player
IPod shuffle Second Gen problem
Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document
Ejecting iPod using Windows Explorer on Windows Vista may corrupt iPod
Some customers may see the following message when connecting an iPod to iTunes 7.2 or later on a computer running Windows Vista.
Microsoft has released an update for Windows Vista that addresses a situation where ejecting iPod from Windows Explorer or by using the "Safely Remove Hardware" feature in Windows Vista could corrupt your iPod. Apple recommends Windows Vista customers who own an iPod install this software update. For information on how to install this Microsoft hot fix, refer to the "Update your software" section below. Tip: iPod can always be ejected safely by choosing Eject iPod from the Controls menu within iTunes.
Microsoft has made this Update for Windows Vista (KB936824) available via Windows Update as well as a separate download package. To download this update via Windows Update follow the steps below:
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, select Check for updates in the Security section. If the Control Panel is in Classic view, open Windows Update.
  3. Click the View available updates link and be sure that Update for Windows Vista (KB936824) is checked.
  4. Click Install.
Sep 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Green/orange flahing light on IPod and no music.
From Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
Sep 11, 2007 | Apple iPod shuffle MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
309 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
