Question about JBL Cinema ProPack 600 System
DVD PLAYER UNABLE TO OPEN DISC TRAY AND ALSO WILL NOT PLAY
  • SALM Dec 26, 2007
    UNIT HAS VERY MINIMAL HOURS OF USEAGE VERY HAPPY WITH SOUND HOWEVER UNHAPPY WITH PROBLEM AT THIS TIME
  • MNDAD Apr 11, 2008
    I have the 600II DVD unit that won't open, Just says "hello" on display. I know it's not jammed, since I can manually open it through the access port on the bottom of the unit. It's out of warranty, and I don't know if I can buy just that component.
    Rick
  • 44 Answers
Sounds like the drive mechanism is jammed, best to take it for a repair quote unless its still under warranty in which case return it for repair or refund.
Posted on Dec 26, 2007
Can the DVD player be played while on it side.
Yes it will play on it's side after the disc has been clamped in the player. If the disc tray is not designed to be upright then the disc will fall out when you open the tray
Sep 09, 2014 | Cyberhome Televison & Video
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
1. Switch the DVD player ON
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
The player just reads "disc error"
If your DVD player keeps reading disc error, it simply means the player is unable to read.
The reason is that the lens of the player is weak and cannot play the disc.
The solution for you to completely replace the lens.
to replace the lens, get a replacement lens from an electronic shop,
get the appropriate screwdriver and unscrew the player,
open up the disc tray and carefully replace the lens,
ensure that you do not tamper with the panel of the player.
once the replacement is properly done,
couple back the player and test with a DVD disc.
take care
Jun 13, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
Unlock dvd player to play all dvd regions
I bought today a Philips HTS 8140 region 4 and i use this solution
1. Abrir a bandeja do aparelho / Open the tray
2. Aperte a tecla DISC / Press DISC buton
3. Digite o código 99990 / Insert 99990 code
4. Feche a bandeja / Close the tray
Jan 12, 2009 | Audio Players & Recorders
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
JBL Cinema ProPack 600 System Logo
164 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
