Question about Vehicle Parts & Accessories
Need Repair/Exact Replacement for Radio Shack Car Alarm
Dear Experts:
The Brain Box for this inexpensive car alam needs to be replaced or repaired(I would hate to change all of the wirining in the car, and I do not want any fancy features - i.e. push button activators for key ring). The unit is called Mobile Alert, keyless electronic vehicle alarm system, with motion sensor, and the catalogue number is 49-759. Radio Shack has been of no help. If I could find an exact replacement, then I could simply plug it back in and the system would work again. If I could find someone to repair this unit, that would be fine too. The unit was made in Hong Kong for Radio Shack, so if I could find the manufacturer, perhaps they could help.
I have one
Posted on May 09, 2008
Car won't start ,alame goes off, how do we disable it, so car starts
U can locate alarm box disconnect and reconnect and try see if it works for U by doing so u will reset the alarm box back to its original dimensions command otherwise might have fault inbound read out to the box need tech check. Good Luck
Dec 21, 2016 | Cars & Trucks
I have just bought a Wharfedale ICS182 in-car radio but it doesn't seem to work. The red light that indicates power works but nothing is happening. Please help.
Take the control panel off.
Turn ignition off.
The alarm led should flash slowly.
Turn ignition on
The alam led should flash quickly.
If it stops flashing, take the radio out and get it repaired/replaced under warranty.
Dec 28, 2010 | Car Audio & Video
How to replace 2002 radio light pont bonnieville and part number
Hello
I have repaired these burnt out display bulbs (3 of them) in GM Delco radio's, it is not a simple repair by any means, the radio must be removed from the car and then the radio chassis taken apart, the very tiny bulbs (size of a pencil point) are soldered to the front of the radio's main circuit board for the display, this job requires special pin point cordless low heat solder gun and a printed circuit board solder removal vacuum, The GM dealer does not service these bulbs, all they will do is remove the radio and send it out for repair to a GM radio repair center, if you do wish to attempt the replacement of the display bulbs they are a 12 volt 60ma, you will need 3 for the display, you can buy them from Radio Shack, the Radio Shack part # is #7219. You can also remove the Radio and send it in yourself for replacement of the display bulbs, this is what I recommend, if you damage the circuit board by applying to much heat the radio is so much junk.
Dec 12, 2010 | 2002 Pontiac Bonneville
The backlight to the display no longer works. The "bulb" seems to be burned out. Is this going to be a cost-effective repair...?
The backlight in your scanner is an 8volt bulb, but your scanner is 10 years old, and the exact replacement is no longer carried by radio Shack. You can, however, replace it with a 6volt 25ma bulb, Radio Shack catalog number 272-1140. Replacing it is fairly simple if you're at all handy with electronics and a soldering iron. Contact your local RS to purchase or order the bulb, and I'm certain that they can have it installed if you're not up to trying it yourself.
Bill B
Listening in since the 60's
Sep 29, 2010 | Radio Shack Pro-2052 Scanner
Need to find replacement padapter no. JoD-41U-02 for pro-2018. Can't locate one. Do you know where I can buy one.
The exact replacement power adapter for your scanner is out of production. Power requirement for the PRO-2018 is 12 volts with a minimum of 300 mA. Radio Shack has a universal power supply that will work, or you can pick one up on eBay for under $20, including shipment. You can also pick up a voltage-specific power adapter on eBay or elsewhere, but you may have to change the DC plug to match your scanner.
Bill B
May 21, 2010 | Radio Shack Pro-2018 Scanner
I have a delphi mifi which is in perfect shape except the ear phone jack is broken, any idea where i can get it repaired?
you can actually buy the ear phone jacks at any radio shack store. they are simple to replace just pull it apart and solder two wires. should be fairly inexpensive to just do it yourself. if you do not feel comfortable doing it any electronics repair shop in your area will be able to do it for you
May 15, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
I have a mitsubishi DLP big screen TV where timer keeps blinking continuously after I have unplugged and plugged in and TV wont turn on.
THERE IS NO NEED TO REPLACE THE BRAIN. THE CAPACITORS THAT ARE NEEDED TO REPAIR THIS PROBLEM CAN BE PURCHASED FROM RADIO SHACK. I REPLACED THE 4 CAPACITORS THAT ARE LOCATED INSIDE THE BRAIN, AND I FIXED IT IN 30 MINUTES, COST OF $8. IT HAS BEEN WORKING GREAT FOR OVER ONE YEAR SINCE.
Nov 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Vehicle Parts & Accessories Logo
308 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
