Question about Samsung CLP-500 Laser Printer
SAMSUNG CLP 500
IT IS READING ( COVER OPEN) AND WHEN I OPEN AND CLOSE ALL COVERS PARTS, STILL SHOWS COVER OPEN. MY EMAI: backbenchav@yahoo.ca. Mobile phone: +255 784 668800.
  • mikeowl Dec 27, 2007
    have exactly the same problem -can't get beyond message on menu
    Novelist:
  • 217 Answers
The order iin which you open and close two of the covers is important, as there is an interlock between two of them. This can (and does) get damaged.
The toner access door is the first one you open, THEN the top cover (the one that gives access to the Transfer Belt and Drum.
Make sure the Drum unit is properly pushed into the printer, and that the Transfer Belt is lacated properly AND the two locking levers fot the Transfer Belt are in their locked positions PROPERLY.
THEN close top cover - you shouldn't need to force it.
Followed by the Toner access door.
Yes check the duplex door too !
If this fails it is likely to be a broken case part, or failed sensor.
Posted on Jan 17, 2008
I can't not get a email address account with yahoo my old emai address was Bernie75m@yahoo.con forgot the password
Yahoo-mail password recovery
Change recover or reset your Yahoo password
or
Mobile phone number and alternate email address
  1. Go to the Sign-in Helper.
  2. Enter your phone number or email address.
  3. Click Continue.
  4. If prompted, enter the CAPTCHA code.
  5. If you can receive text messages to the number listed, click Yes, text me an Account Key.
Oct 29, 2016 | Yahoo Computers & Internet
Tip
How to repair your Mobile when it dropped in water?
<p><span>If you worry as your mobile phone drop in water. It may happened by rain or else. However, there is no need to panic. You can save your mobile by repairing it.</span><br /> <p><span> </span><br /> <p><span>. Quickly open all cover part as possible such as the cover, SIM card, memory card battery, etc</span><br /> <p><span> </span><br /> <p><span>.Take a piece of dry cloth or tissue paper for removing the water. If you sure that dry it completely, or some inside part out of your reach.</span><br /> <p><span> </span><br /> <p><span>. You can use a hairdryer and begin to drying the mobile by put it in the place where battery is located, and keep it too close to the mobile it may harm the electrical mechanism of the mobile phone. </span><br /> <p><span> </span><br /> <p><span>. Keep the mobile phone in sun light or in warm place for twenty to thirty minutes.</span><br /> <p><span> </span><br /> <p><span>. You may take off the covers and battery from the mobile phone. Keep the mobile in a dry or warm place to remove the water from the mobile phone. </span><br /> <p><span> </span><br />
on Dec 24, 2010 | Cell Phones
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
Image of last print shows up on presant print
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Feb 11, 2014 | Samsung CLP-315W Laser Color Printer
Cover open samsung scx-4521f
There is probably a broken sensor on your printer. Try to open and close the cover some times it works. If not you need to bring it to samsung technician for fixing it.
Apr 21, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Mobile cam is problem . It shows open lens cover. I opened lens cover after that also shows like that i want clear solution for that problem.
Oct 31, 2010 | Sony Ericsson W700i Cellular Phone
Just bought MX870 and put power on and it says "The feeder cover is ope Close cover and press ok." I closed every cover and pressed ok but still shows that error.
The two covers on top are just not aligned properly. Open both top covers (one opens to the right one to the left). Close the cover that opens toward the right 1st (you should hear it click into place) then close the second cover. Press "ok" should be good to go.
Sep 01, 2010 | Office Equipment & Supplies
On activator mod.8585 procedure to remove side covers to replace comp, head assembly my e mail ,,wcherwonka@yahoo.ca Thanx Walter..
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will find the replacement part at shaveroutlet.com
Aug 03, 2010 | Braun Health & Beauty
Samsung CLP-500 Laser Printer Logo
188 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
