My music reads error and it wont pop up when i plug it in
I need the drivers for my gpx mw3837. when i plug it into my computer nothing pops up when i try to listen to the music it reads error i have tried evrything
Received for Christmas when I connected device to computer I get the message that the USB deviced attached is not recoginized by windows or has malfunctioned. Do you have any suggestions.Received for Christmas when I connected device to computer I get the message that the USB deviced attached is not recoginized by windows or has malfunctioned. Do you have any suggestions.
After I uploaded music, I go to turn on the mp3 player and it flashes an error code. Please help!After I uploaded music, I go to turn on the mp3 player and it flashes an error code. Please help!
You can't post conmments that contain an email address.
1) plug in 2) go to "my computer" or "computer"(vista+) 3) look for an extra drive, should be labled GPX 4) double click the extra drive 5) drag music files there
There could be more than one reason - the most likely is that the HOLD button has been engaged. Your USB port may not be 2.0 - try a different usb port on your computer. You could be running Windows Vista or some other incompatible OS. You may have forgotten to download the install CD. The following information is straight from GPX themselves: "What if I cannot troubleshoot an error message?"
You will need to format your player. Connect the player to your computer using your USB cable. Make sure the HOLD switch is in the unlocked position. Formatting can be done in two ways:
Within the Start menu, select My Computer. In the My Computer
folder, right-click on the icon representing your GPX player. You will
be given a list of options. One of them will be to Format your drive.
Click on this to erase everything on your GPX player. A warning will
pop up to make certain that this is the choice that you want to select.
Once your player is formatted, reload your music files onto your GPX
player.
Open Windows Media Player. In version 10,
open the Sync tab. On the right-hand side, there will be a listing for
GPX audio player. Just above this and to the right are a set of four
icons. The icon furthest to the right represents, “Format storage
media.” This icon resembles a pencil. After formatting, synchronize
music to the player. In version 11, open the Sync
tab. On the far left column, there should be a listing for GPX Audio
Player. Right-clicking on this listing will result in a menu containing
Format. Select this to erase everything on your mp3 player.
Here is a useful link: http://www.gpx.com/store/p/187-MW238B.aspx
Let it recharge for a few hours - when an mp3 player won't turn off, use the reset button instead of letting the power drain down. Actually, i take it back - this is the worst most godawful manual I have ever seen - this is the first Mp3 player I have ever seen without a reset button.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Ive uploaded a bunch of song and when i get to certain ones it says ERROR
