Question about Philips Lands Phones
Phillps 8 pin RJ45 Wall plate wirring Diagram
I also bought the Phillps 100ft roll of cat-5 cable the problem is there is no wireing diragram for the for the wall plate colors on the wall plate are red, white, blue, green, yellow,orange,brown,Dark Blue and the cable colors on the Cable Are Blue and White with a blue line running in with white Green
and Brown, Orange Also like the blue all Colors have a white wire with each having Brown ,Green,Orang streaks on the white wire And so my problem is How do I match up the wiring from cable to the wall plate
  • 3422 Answers
SOURCE: I am trying to install
HI,
Just Click HERE all the setup instructions are given step by step with the photos.
For more info you can click HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 28, 2008
  • 4 Answers
SOURCE: phone socket
I found some good information on this site: http://www.ling.upenn.edu/~kurisuto/phone_wiring.html.
He lists that the old style wire has become obsolete, and shows a diagram of how they line up to the new style.
Posted on Jun 17, 2008
playaway
  • 18 Answers
SOURCE: wires from the wall are
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Posted on Aug 11, 2008
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: GE Network & Coax Wall
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Posted on Jun 05, 2011
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
Wiring diagram cat5e wall plate
Google"RJ45 pinouts".There is some sight I found(free)that has connector pinouts for all kinds of stuff.There are several different ways to configure an RJ45(8 pin)jack,depending on the application.
Sep 16, 2012 | Gefen Dual CAT5 Wallplate Ivory Network...
I have been on many sites with Cat 5 systems. What I cannot understand is why are the sockets numbered oddly i.e 1--6 2--7 3--8 etc. Instead of 1--2 3--4 5--6 etc.
Not sure if I understand your question.
Cat 5 (and higher) cables consist of four twisted pairs. The idea is, that disturbances by magnetic fields compensate each other this way. I suppose that the arrangement of the wire on the plugs and jack come from good ols analogue days, where the telephone-call was only on two wires (=one pair). To keep it as undisturbed as possible, the center of the plug (pins 4 and 5 on a rj45) was used. The next pair was spread over them and therefore used pins 3 and 6. Pair three was put on pin 1 and 2, and pai four on pins 7 and 8.
hth, Karl
Jun 17, 2011 | Cat5e Cat.5E Connection Box (512114)
Cat5e Single Socket RJ45 Ethernet Network Face Plate
My preference is to use the T-568b if there is not already a standard where you are doing the installation at. The A and B are just different standards to terminate an ethernet cable.
TIA/EIA-568-A, T-568B RJ45 Wiring Standards
To answer your question..If you want a straight through connection you would use T-568B (or T-568A) at both ends of the cable.
T-568B T-568A
Pin Color Pin Name Color Pin Name
1 Orange Stripe Tx+ Green Stripe Rx+
2 Orange Tx- Green Rx-
3 Green Stripe Rx+ Orange Stripe Tx+
4 Blue Not Used Blue Not Used
5 Blue Stripe Not Used Blue Stripe Not Used
6 Green Rx- Orange Tx-
7 Brown Stripe Not Used Brown Stripe Not Used
8 Brown Not Used Brown Not Used
Dec 31, 2009 | Cat5e Cat.5E Connection Box (512114)
2 Orange --- Orange
4 Red --- Blue
6 Yellow --- Green
8 White --- Brown
Apr 11, 2009 | Computers & Internet
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
HOW DO I CORRECTLY WIRE THIS WALLPLATE TO MY CAT5e CABLE AND PHONE LINE. WHAT COLOR BELONGS TO WHAT?
http://www.ertyu.org/steven_nikkel/ethernetcables.html
this link covers proper pinout for cat 5 cabling. (RJ45). A phone line is RJ11. You can run ethernet cable through a wall and terminate it at a wall plate designed for ethernet (not a standard phone wall plate). You can't use the RJ11 cable currently in the walls for ethernet.
May 02, 2008 | Computers & Internet
Lands Phones Logo
236 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
