Question about Fostex MR16HD/CD Digital Recorder
Guitar Input Level
I have recently bought the MR16 in order to record guitar on it, but when I hook up my guitar, foot pedal, and amp I cannot record anything. I have tried and got it to record some, but I don't know how I did that and even then it was very hard to hear. I really could use some help on how to set up a guitar, amp and foot pedal so I can record music.
  • 178 Answers
I can help
Posted on Feb 11, 2008
Around 6 to 10 days ago I paid a seller for a Pyle Pro guitar foot pedal and I have not yet received this Pyle Pro foot pedal.
You need to contact the platform (ebay, amazon, ect) that you bought the item on to get the contact info for your seller. You can also contact the payment service you used (PayPal, credit card issuer, etc). If the seller cannot provide proof of shipment, I'd consider cancelling the order.
Jun 27, 2016 | Computers & Internet
What do i hook plug from marshall dfx foot pedal to amp and guitar
If you're asking if the foot pedal goes between the guitar and the amp or straight in to the amp then it's the latter.
Dec 14, 2013 | Marshall Amplification Music
Is there a guitar hero foot pedal wire replacement as the wire to hook up pedal to drums is broken? Can I buy just the wire or do I need a whole new foot pedal? And if I can buy the wire, where do I buy...
you will have to get a new foot pedal var fctb_tool=null; function FCTB_Init_62176759b3424b9cbe761805261ece8a(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_62176759b3424b9cbe761805261ece8a(document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']); delete document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316'] var fctb_tool=null; function FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(document['FCTB_Init_f65b37e3b16a4105b681111044638705']); delete document['FCTB_Init_f65b37e3b16a4105b681111044638705']
May 05, 2011 | EA - Electronic Arts Rock Band
This is for the takamine DI+. Is there a wiring diagram as to how to cable from my guitar to the amp? Basically how do you connect the DI+ using stomp boxes. Also, is their a special cable to use to...
Most of the pedals are daisy chained right from the guitar. The output of the daisy chain goes into the DI box set to ground lift. An XLR to XLR cable goes from the DI box to the amp or mixer. Do NOT try to loop the sends and receives of the amp through PEDALS! The sends and receives are LINE LEVEL which is too high for pedals. The sends and receives are for external effects MODULES and EQ's that take line level. Some of those effect units have a foot switch to turn them on and off.
May 05, 2011 | Takamine Acoustic DI+ Direct Box
Garageband not picking up the guitar through imic
You could try double clicking on the amp image in the Guitar Track panel on the right of the screen, and when it spins around, you should see controls for Input Source, Monitor, Recording Level etc.
Select Monitor: On
I found that to be the source of my frustration, when I couldn't get any sound.
Hope this helps
Nov 09, 2009 | Apple Griffin iMic External Sound System
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
How does my effects pedal hook up? Through the jacks on the back or through the guitar jack in front?
You need two cords..
One from the guitar to the pedal ( where it says guitar or IN )
Then the other cord from the pedal ( where it says amp or OUT ) to the amp..
The pedal also might take a battery..
Jul 08, 2009 | Behringer ECM8000 Professional Microphone
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
The proper way of setting up a foot board to my amp and guitar
Run a jack from your guitar to Input R Mono on the pedal.
Run a jack from Output R Mono on the pedal to the input of your amplifier.
There is a switch for guitar or Bass. Put the swich on guitar
You do not need a preamp to use this pedal.
Hope this helps,
Maxx.
Aug 27, 2008 | Boss Music
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
89 people viewed this question
Top Fostex Televison & Video Experts
Michael Galve
Michael Galve
pawnpower
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
