Question about Microsoft Xbox Console
XBOX Console error 07 now error 12
Hi, I am trying to fix my sons XBOX console at first he could not remove a stuck cd, we got that fixed by drive sounds a big rough, got the flashing red light and read up reseated ribbon cable, changed shunts to from CS to Master with Slave, to Master and now back to CS receiving flashing red light with error 12, would appreciate any suggestions. Thank you, Al. alpujadas@hotmail.com
  • skipperose Jan 05, 2008
    red light flashing and error 07 comes up what is my problem and how do i fix it?
  • 21 Answers
12 - kernel - DVD parameters (PIO/DMA)
Same as #10, only not very common.
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8. But also make sure the yellow cables are properly connected to the motherboard and the dvd drive.
1. Make sure ide cables are connected good.
2. Make sure the yellow cables are good and properly connected.
3. Still no succes? Try another dvd drive of which you are sure it is working.
6 - kernel - Cannot unlock HDD
If you understand the above, you should be able to understand what this means. It means you are trying to boot up the xbox with an harddisk that is locked in combination with ANOTHER motherboard than you are using it with right now.
What can i do about it, you ask? Well place the harddisk back in the xbox where it came from. After that, UNLOCK the harddisk with the same procedure i explained above (see error 5). Now when the harddisk is UNLOCKED, put it in the xbox which gave you the error. Now when you boot up with the chip ON it should not give you an error anymore.
However when you put the xbox on with the chip OFF your xbox will give you an error. (error 5) So to make sure you can boot original and boot with the chip ON. Next do the same as above: "Boot up your xbox with the chip on. Preferrably with a slayer evo-x cd. Now you choose "Eeprom management." Than you choose: "Lock hdd." It takes one second. After its ready it should say something like "Done"
When it is ready just turn off your xbox. Disable your chip and try to boot original. Now there should be no more error.
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If that won't work try another harddisk. If there is still no go, try to set the jumpers on the rearside of the harddisk drive. Set it to master or cable select.
8 - kernel - No HDD found
Please make sure your xbox hdd is attached properly. Most of the times the Ide cable came loose, or isn't seated properly in the IDE port of your harddisk. ALso make sure the power supply cables are intact and working.
Make sure the ide cable is also connected properly to the rest of the hardware (dvd and motherboard).
Posted on Dec 30, 2007
My son's x box has 3 red lights on the circle and won't switch on
Refer to this thread for the xbox 360 "red ring" problems. http://forum.teamxbox.com/showthread.php?t=472553
Mar 07, 2011 | Microsoft Xbox 360 Console
How to fix a grey screen on the xbox360??
How to Fix Xbox 360 Green Screen:
1)
Check for loose cables.
2) Try to unplug all cables except the power cord, and plug them back in.
3) Remove the hard-drive, then restart your console.
4) Once the Xbox 360 green screen problem is gone, get the hard-drive back in while your console has been shut down.
If these tips didn't fix your console, then you have to send it to Microsoft.
Microsoft has some kind of repair service to fix your Xbox 360 green screen error, but it's obvious that it's not for free.
Feb 19, 2011 | Microsoft Xbox 360 Console
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
X box cant not rid the games ask m to hopen tray in all cd
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Mar 10, 2010 | Microsoft Xbox 360 Console
Hi - my sons xbox won't play any discs. tried unplugging etc - should i get a disc cleaning kit ?
This is quite a common error.
Feb 26, 2010 | Microsoft Xbox 360 Console
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
Xbox E 73 error
Hi Brett,
FYI. the 3yr extended warranty only applies for the 3RED LIGHTS and E74 issues only..if the console is already in the service center,you dont have to worry anymore,microsoft technicians will surely work hard to get it fixed. just wait 2-3weeks for the whole repair process,and you& your son will enjoy playing xbox in no time. :-)
May 15, 2009 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Put this in an xbox 360 console
Did you try using a cd lens cleaner in the XBox 360 dvd drive? Check the cds that they are not scratched, and you could have your son try the discs in another XBox 360.
Nov 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
157 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
