Question about Magellan RoadMate 700 GPS Receiver
I have disconnet my 4040 Magellan from the cigarret lighter but it is still on. How do I turn it off.
  • 50 Answers
On the left hand side there is a silver button,that is your on/off ,also make sure you read your manual carefully also it shows you how to operate your unit
Posted on Dec 26, 2007
Blowing number 2 fuse in dash panel
fuse #2 E7 D8 goes only at cigarrete lighter and to data link connector, remove the socket at the rear of cigarrete lighter and install fuse, change the cigarrete lighter when it is shorted or there will be a small piece of metal left inside the whole,
Aug 05, 2010 | 2000 GMC Jimmy
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
Are there any free updates for a magellan gps 4040
  • The only free update for your 4040 is the latest firmware or you can call the tech support of Magellan and ask if you can still avail the latest maps for your 4040 don't forget the recepit when you call them, they may ask you to send it to them for verification.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 10, 2010 | Magellan Maestro 4040 GPS Receiver
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan 4040 wont turn on
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 13, 2009 | Magellan Maestro 4040 GPS Receiver
2003 BMW X5 4.4L, cigarret lighter does not work
have you checked the fuse for the cigarret lighter in the fuse box. You should be able to look in the car manuel to see which fuse is the cigarret lighter then pull it out with either needle nose pliers or a provided fuse puller and check to see if the little wire inside the fuse is broken. if it is then replace that fuse with one of the same amperage rating. If not and you really want to get into it buy or borrow a volt meter with a continuity tester (checks if wires have breaks and shorts in them) and test contiuity from one lead of the cigarret lighter to the other with something plugged in and on that you know works like a phone charger. Then test from the positive lead of the battery to the positive lead of the lighter and the negative lead of the lighter and something grounded like the car's frame or a body panel that is bare metal like the floor board make sure you scrape a little paint off to test this.
Aug 06, 2009 | Car Audio & Video
Part of cigarette lighter connection stuck
Use a clean ice-cream stick and super glue and pull it out.
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
MAGELLAN GPS WILL NOT POWER UP
the folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Sep 24, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
